AV Receiver / Speakers Power Rating Matching
essaabbas
essaabbas Posts: 12
edited March 2014 in Speakers
Hello everyone,
I would really appreciate if you could help me clarifying the following issue for me 
The specification sheet of my receiver (Onkyo TX-NR727) stats that the output power is 110 Watts per Channel (8 Ohms, 20 Hz 20 kHz, 0.08% THD) and I am planning to install the following 7.1 combination?
• QTY-1 Subwoofer PSW series PSW505
• QTY-2 Monitor 70 II (Front R+L) 275 Watt each
• QTY-1 Polk CS20 (Central) 175 Watt
• QTY-4 Monitor 30 II (Surround) 100 Watt each
My question, are those surround speakers (Qty-4, monitors 30 II) will be affected at high volume considering their max power rating is 100 W where is the amplifier will be giving 110 W.
Post edited by essaabbas on
  • ALSATIAN in USA
    ALSATIAN in USA Posts: 127
    edited February 2014
    My response is NO!... In fact (under-power at full volume is dangerous, burn tweeter!)...Set your speakers also to "SMALL"
  • essaabbas
    essaabbas Posts: 12
    Thank you ALSATIAN, do you recommend me to upgrade them to M40 instead?
    F1nut Posts: 51,997
    Forget you ever read the max power stuff. Set your speakers to small. Consider buying a Pioneer Elite SC series the next time.
    BTW, that 110wpc rating is with only 2 channels driven, with 7 channels driven your AVR is putting out 45wpc.
    Test results, http://www.soundandvision.com/content/test-report-onkyo-tx-nr727-av-receiver-page-3
  • essaabbas
    essaabbas Posts: 12
    Many thanks to you F1nut, I am new to this business and everyday I am learning :)
  • PolkieMan
    PolkieMan Posts: 2,446
    edited March 2014
    What you want to do is let the sub woofer carry the bass (speakers set to small) that way you don't need as much power.
    Bass and volume is where the power needs really goes up.
    Also you don't need to play it so loud that your ears bleed okay.
    You don't have a very large room, like 30 x 20?
    Don't put your Onkyo in an enclosure because as it gets hot,
    your power output goes down and so does the life
    of you unit.
    A rule of thumb is twice as loud means 10X the power.
    My Onkyo never goes over 60, it's limited, and always comes on at 25,
    set the limits on yours.
  • essaabbas
    essaabbas Posts: 12
    edited March 2014
    PolkieMan wrote: »
    of you unit.
    Thank you PolkieMan for such great info, however, can you elaborate more on "A rule of thumb is twice as loud means 10X the power. "
  • PolkieMan
    edited March 2014
    Well it is not as you think most of people would think that twice as loud is only 2x the power.
    In order to understand this more clearly we have to look at decibels and watts.
    Now I usually have my system a 70-80 decibels and in 2 channel mode, Onkyo pure Audio
    (that's where you are getting the rating advertised like 105 WPC).
    http://www.parts-express.com/mini-digital-sound-level-meter--390-722?utm_source=google&utm_medium=cpc&utm_campaign=pla
    http://www.audiology.org/practice/resources/PublishingImages/NoiseChart16x20.pdf
    Play around with this calculator and you will see what I mean, try changing the decibels from 80 to 90, wow see
    http://www.crownaudio.com/elect-pwr-req.htm
    essaabbas wrote: »
