? About Bridging Amps & SDA's
boston1450
boston1450 Posts: 7,758
edited February 2014 in Vintage Speakers
Ive heard its a no-no . But a friend of mine was asking why & i said i read it couldnt here on a older thread. So' if it could be done - how would it be set up ?
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
Post edited by boston1450 on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    SDA signals are tough on amps because they resemble hooking amp channels together and that can be seen as a short circuit by the amp. This is worse when amps are totally separate pieces of gear.
    pitdogg2 Posts: 27,309
    Bridged amps are no longer common ground. Other thing is if you bridge an amp with a 8ohm speaker it sees 4 ohm, bridge and 4 ohm speaker now amp sees 2ohm.
  • boston1450
    Great answers. Thats sums it up quite well. We got into a long discussion & i just didnt know how to answer the question as to if it COULD be done in adding grounds or other tech processes above my knowledge. Thanks
    Randy-Maine
    by David WMG
  • Schurkey
    Schurkey Posts: 2,122
    IF (big IF) the SDA is of the last two generations (pin/blade SDA cable--such as your SDA 2B or 1C) you can install an isolation transformer in the SDA interconnect (Polk AI-1, or aftermarket "Dreadnought" upgrade.) Once the isolation transformer is in place, you no longer have a need for an amp with common-ground between the channels. Bridged amps are fine.
    OLDER SDA speakers (blade/blade or previous connection) cannot use the isolation transformer, and are therefore NOT USABLE with any non-common-ground amps including bridged amps as long as the SDA interconnect is plugged in .
  • boston1450
    ^^^^ i have read that here - when people wanna use a certain amp Not Common Ground. So that makes sense. I myself would never need to do that,as room size is a factor. They sound great to me the way i have them now. He went with me to pick up my RX-V1 & we saw this guys set up & he questioned why i dont do that to get better power to the speakers. I will show him this thread
    Randy-Maine
    by David WMG
