Researching amps
Easy Runnin
Easy Runnin Posts: 501
edited February 2014 in 2 Channel Audio
A carver tfm 45 came and went on my local CL. In your opinion is that amp worth $250? I'm looking for something better then my NAD 2400 to feed my 1Cs.
HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5
Post edited by Easy Runnin on
    EndersShadow Posts: 17,692
    Snag it up now. If you dont like it, I can get a buyer for it VERY quick and you can get your full price back more than likely.
  • erniejade
    erniejade Posts: 6,321
    As long as it doesnt need a recap, they were a solid amp! Good sounding especially for the $. They were common ground and can run SDA, and good to drop to 2 ohms as I heard my carver amazing when I had them on a 45
    F1nut Posts: 51,701
    Better how?
  • Easy Runnin
    Well that amp is no longer available.
    Better how?
    Due to my limited knowledge I really don't know how to answer that. Hopfully someone here can. On a previous post you indicated that the 2400 would work but I would not get out of them what they are capable of.
    At this point I am only researching, so what might be a better choice. And just to narrow it down let's assume a $300 budget. Not that I'm set on this amount, but i think this figure could be doable.
