B&K AV5000 Pops when turned off and on
bcline
bcline Posts: 59
edited February 2014 in Electronics
I just hooked up a used B&K AV5000 series ii 5 channel amp to my surrounds and center channel using my Onkyo TX-SR806 receiver as a preamp. I'm running a Parasound 2250v.2 amp on my SDA-2A mains. The Parasound has been perfect. No pops nothing. But the B&K makes a loud pop on all five speakers when I switch it on and also when switched off. Once on, the amp sounds really good, but I do notice a very faint buzz only on the center channel speaker... nothing on the four surrounds.
So, do I have a problem with the amp and can it be fixed? I know B&K is out of business and I picked up the amp on the cheap. It does not matter the order I turn on preamp and amps. No matter what, I get a pop both when turned on or off.
Post edited by bcline on
  • bcline
    bcline Posts: 59
    Well I guess nobody knows... I have isolated the problem a little more. It appears that the 5th channel which runs my center channel is the only one popping and humming. The other 4 channels are quiet and clean. The center does work otherwise but has an annoying hum always... even if preamp is off. Tried changing cables... ran the center off one of the other channels, etc. Definitely is channel 5 of the amp causing all the problems. Are these amps beyond any repair since B&K is now out of business?
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Sounds like it needs a recap job. The pops and the center channel hum are the capacitors charging and discharging on power up/down. B&K is a brand that any decent electronics repair shop should be able to service. You might call A Plus electronics in Park City since they were B&K dealers local to you.
  • Zentish
    Zentish Posts: 127
    you could put the center back on the 806 until you figure it out.
    Receiver: ONKYO TX-NR929 7.1 AVR 130wpc
    Mains: 2x Polk RTA 8TL's
    Center: Polk CS245i
    Surrounds: 2x Klipsch RS-41ii (because they fit perfectly over the door and window)
    Rear Surr: 2x Polk M4a '90
    Subwoofer: Speakerlab DAS-SW dual-voice-coil 10" '88 30Hz-150Hz
    Subwoofer Amp: ONKYO A-8019 AMP '85 100wpc
    Display: Samsung 55" UNC55-8000 3D LED
    Console: Xbox360
    DVR: custom MythTV rig w/ 3 tuners OTA
    Zone2: 2x Polk M5b '87
  • bcline
    bcline Posts: 59
    Actually, the owner at A Plus is a good friend. I helped install car stereos for him 30 some years ago. He said B&K is out of business and ATI is not really doing anything to help support them so far. So, I would have to find an independent repair shop that could do it.
  • bcline
    bcline Posts: 59
    Zentish wrote: »
    Yeah, that is what I have done for the moment. I might instead put the side or rear surrounds back on the Onkyo for now as the center really sounds much better off the B&K and since the majority of sound is through that channel...
  • Zentish
    Zentish Posts: 127
    bcline wrote: »
    Makes total sense. Might I suggest you write down whatever it is you end up doing - I keep a notebook near my AVR with all the input and interconnect mappings so when I come back to work on it 6 month later I'm not faced with having to re-map all the cables every time (faulty memory). There are lot of darn cables back there...
    Center: Polk CS245i
    Console: Xbox360
