Definitive Technology TL vs non TL
halo71
halo71 Posts: 4,638
edited February 2014 in Speakers
I searched a little on the net and didn't find an answer really. But can someone tell me what the differences are in the TL and non TL models? Like for example the BP2000 and BP2000TL?
--Gary--
Post edited by halo71 on
  • Mystery
    Mystery Posts: 2,546
    Need to search little more...
    Here is from avsforum:
    Originally Posted by logicators View Post
    Don't know what TL technically means but Deftech TL models contain ported subs with beefier amps as compared to their non-TL counterparts.
    >>That's what a salesman told me about 10 years back.
    VR3 Posts: 29,549
    It is most likely just marketing...
    Maybe "Top line"
    IE: The BP2004 versus BP2004tl
    2004 - 2 x 5.25, 2 x 1" tweeters, 10" ported sub
    2004tl, Same - handles slightly more power...
    I believe one feature they added was "tri-wiring inputs" and maybe slightly better amps.
  • [Deleted User]
    [Deleted User] Posts: 1,223
    I posed this question to Dave Peet, the Head of Sales for Definitive Technology because I was interested in the answer myself. His reply was as follows: The TL designation refers to either a difference in amplifier platform or transducer loading depending on which product you are referring. In all cases the TL designator came after the non-TL designation with the TL being the improved version. Hope this helps. Cheers.
  • zingo
    zingo Posts: 11,258
    TL stands for Transmission Line, referring to the subwoofers in those super towers, but it seemed to be a bit of marketing as it wasn't a true transmission-line loaded woofer. However, the TL designation, as mentioned above, also referred to an updated model as among some connectivity differences, the BP2000 had a 15" sealed woofer and 300 watt amp and the BP2000TL had a 15" ported woofer and 500 watt amp.
  • Mystery
    nap wrote: »
    I did the same thing.
    I emailed Friday and got a reply today which is slightly different than what you got.
    TL does stand for Transmission line but a simulated version is used with more powerful amp and ported design for tighter and more powerful bass.
    Hello,
    Thank you for your recent email to Definitive Technology.
    The TL would stand for Transmission Line in which we used a simulated TL configuration with the Port and amplifier combo to make the bass a bit more powerful and tight.
    Thank you,
    Thomas “T.J.” Baust
    Customer Service Technician
  • halo71
    halo71 Posts: 4,638
    Thanks guys for getting that info! :)
    --Gary--
