Driving the lsim707 speakers
I have an Onkyo TX-NR5010 receiver. I want to buy a pair of LSIM707's but I hear they are hard to drive. Does anybody know if this receiver will drive these. I have monitor 70's now and it does a good job with these. If not what do you recommend for an amp. I think the 5010 has 280 watts per channel.
Post edited by gmcgee78 on
First rule of thumb, there is always something better. Second rule of thumb, be careful with power ratings. I am sure this AVR will work fine, assuming you aren't in a cathedral size room. It's actual rating is 145/W per channel at 8 ohms with two channels driven, which is respectable.
http://www.onkyousa.com/Products/model.php?m=TX-NR5010&class=ReceiverLumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Large 4-ways like the 707's seem be the the reason amp companies make 200-300 watt per channel amps. Seems like the right combo. However, your AVR is such a brute, it measures well:Sound and Vision wrote:http://www.soundandvision.com/content/onkyo-tx-nr3010-av-receiver
Two channels driven continuously into 8-ohm loads:
0.1% distortion at 167.8 watts
1% distortion at 189.5 watts
Five channels driven continuously into 8-ohm loads:
0.1% distortion at 122.1 watts
1% distortion at 142.2 watts
Seven channels driven continuously into 8-ohm loads:
0.1% distortion at 114.1 watts
1% distortion at 127.2 watts2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
