Removing an adhesive sticker from CSi5
gurot1
gurot1 Posts: 519
edited February 2014 in Speakers
I hope I am posting this in the correct forum. I recently purchased a used CSi5, which sounds better than the CSi3 that I had previously. The are a few stickers from the store that the original owner bought it from (it was an open box). Those stickers have been on for a few years now. What would be the best way to remove the stickers (when I tried to peel on of them of, the paper was splitting and leaving adhesive residue behind), that will not damage the black finish of the speaker?
lsim705,lsim706c,lsif/x(4)+mc80(atmos)
rti6,csi5,fxi5
  • seabeerob213
    seabeerob213 Posts: 1,843
    goo-gone on a rag, wipe it on, leave fore a minute, then scrup, take a dry rag and wipe it dry when youre done.
  • heartystatue
    heartystatue Posts: 329
    You can try also a little rubbing alcohol. Try in a non conspicuous spot first to make sure it wont damage the finish. It shouldn't but just to be sure.
    HT: LSI15, LSIC, LSIFX, Emo XPA-3:biggrin: Onkyo TXNR809, Sony BDP-S500, PannyDMP-BDT320, MIT S1 SC. Mit 73842dlp
    2ch: SDA-SRS 2.3 Fully modded. BAT VK500 w/batpak, BAT VK5I, Essence HDACC.
  • WagnerRC
    WagnerRC Posts: 2,227
    wd40 works very well
    pitdogg2 Posts: 27,917
    WagnerRC wrote: »
    this^^^^^^^^
    goo gone does also work but some of it is naphtha as in lighter fluid...there is also a citrus based goo gone.
  • seabeerob213
    i thought all goo gone was citrus? thats what i was referring to
  • halo71
    halo71 Posts: 4,644
    WagnerRC wrote: »
    DSkip wrote: »
    Lick it.
    ^^^^These!! lol I've had great success with WD40. Works very well to take permanent marker off painted guitar bodies as well.
    --Gary--
  • Mikey081057
    Mikey081057 Posts: 7,127
    A hairdryer can soften the adhesive used carefully. and then wd40 to remove the residue
    Garage | Polk Monitor 5B's
    mhardy6647 Posts: 35,562
    GooGone is expressly for removing adhesive residue and it's danged good at it. It is certainly capable of attacking certain finishes/materials, but I've had zero disasters with it to date (I'd definitely not recommend it for lacquer a priori). A little goes a long way. Moisten the spot, wait as long as your own patience permits, and rub off with a soft cloth. Repeat as necessary.
    Test on an inconspicuous spot first to ensure it's safe! ;-)
  • leftwinger57
    leftwinger57 Posts: 2,917
    I like this thread because it's happened to me and it continues. For what ever reason the 2 local GoodWill stores sticker their stuff all over the place. Now I'm talking right in the middle of LED readouts,a prominent knob or 2,tops of speakers and and LP fronts. I go to the manager and tell the dude listen I understand you have tag your items but how about on the bottoms of receivers or on the backs of albums and more out of the way places on other things. The dude shrugged it's our policy. Now solvents ng for plastic so warm water soak and wait and scrub. The albums not so much you can do. Petty yes but when you get a great deal it's annoying.
    Blow torch....
    Warm water usually does it, and a little patience.
    there are plastics and there are solvents ;-)
    A little digging on teh webs will turn up compatibility charts for plastics and solvents - also to be remembered are the variables of time and temperature. Generally speaking, very polar organic solvents (e.g., methanol, ethanol, isopropanol) are OK for many plastics and finishes (again, not laquer!). Acetone will craze or haze many plastics. Nonpolar solvents like hexane, toluene are likely to attack many plastics. I remember with great chagrin dissolving a disposable plastic (polystyrene) pipet with a solvent called THF (tetrahydrofuran) in grad school :-P I put the pipet in the liquid and it just disappeared! D'oh.
    Warm water and a little detergent/surfactant may work for some things. Extremely gentle abrasives (the most gentle include toothpaste and Mr. Clean "Magic Sponge", as well as emery cloth) can be used with care.
    Where it gets tricky, e.g., is silkscreened labeling on aluminum panels or glass. Ancient tuner or receiver glass can be incredibly difficult to clean without inadvertently removing the dial labeling (don't ask me how I know this!) :-p
  • jeto
    jeto Posts: 17
    Yep, agreed, best way IMO
    gudnoyez Posts: 8,232
    I hate that annoying residue left behind from those stickers they use across the top of a new cd, that gets left behind when you pull it off mostly a little at a time. I use goo gone for that a little dab on a cotton ball and wahla residue gone. I also suggest test in a inconspicuous area before using on a painted surface.
    DSkip wrote: »
    Lick it.
    Ya know....I was hoping others would have followed your lead there. I was just roflmao thinking about if he came back and said licking it took too long and tasted like crap.
    Next time gents....get with the program. LOL
  • gurot1
    gurot1 Posts: 519
    DSkip wrote: »
    Lick it.
    LOL. Just thinking of licking that adhesive is leaving a bad taste in my mouth!
    Thanks for all the ideas, I will try something out this weekend (hopefully earlier!) and report back!
    rti6,csi5,fxi5
  • PolkieMan
    PolkieMan Posts: 2,446
    Some are mint others pina colada
    gurot1 wrote: »
    lol. Just thinking of licking that adhesive is leaving a bad taste in my mouth!
    Thanks for all the ideas, i will try something out this weekend (hopefully earlier!) and report back!
  • Geoff4rfc
    Geoff4rfc Posts: 3,062
    DSkip wrote: »
    Lick it.
    You can be a sick bastage :smile:
    tonyb wrote: »
    Tony, if it tastes like crap, you're licking the wrong side.............
    Racing bikes for so many years and having the amount of ever changing sponsor list meant changing stickers every year, I agree with the blow dryer method the most, this heats up and softens the adhesive and allows the non chemical solution to remove the excess much easier and more efficiently.
    And if THAT doesn't work, then by all means..........lick the crap out of it.............
    Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3
  • gurot1
    gurot1 Posts: 519
    I used a hairdryer to heat up the stickers and removed them...the slower I went the less adhesive left behind. I then used a wash cloth with soap and water. Looks much better. There is still a little bit of adhesive visible, but not too bad. I couldn't find my bottle of goo gone. Once it turns up I will remove the remainder...no licking required lol
    rti6,csi5,fxi5
  • gurot1
    gurot1 Posts: 519
    Here is a late update...used goo gone. Put some on, left it on for a couple of minutes, scrubbed it a bit and then washed off with a little bit of soap and water. I would say 75 percent off the remaining adhesive was removed. One more treatment should do it, but I too lazy right now to do that right now. The adhesive not really noticeable, probably just noticeable to me because I know the stickers were there. Most importantly, no licking required!
    rti6,csi5,fxi5
