Alternative to Google Music? Cloud Storage/player unlimited??
rromeo923
rromeo923 Posts: 1,513
edited February 2014 in Going Digital
I use Google Music to listen to my flac files thru my phone/tablet in my car. It has a limit of 20,000 files you can upload. I am also not super excited about the player etc.
I have a bit more than 20,000 files. Is there an alternative that works similarly but allows unlimited files or at least a bit more? Is there a better player for my android devices that can access my google music/cloud files??
I got static in my head
Post edited by rromeo923 on
  • rooftop59
    rooftop59 Posts: 8,121
    Wow do you really need more than 20k files on the go? As far as apps, what don't u like about it? I've uses it for years and then it works just fine. The only alternative I know of is melodies but its only for iPhones. As far as cloud alternatives go, you'll have to pay and I doubt it will be as easy to access on your phone. Basically the alternative is itunes, and you'll have to pay for atorage and use crappy itunes...
    Game Room 5.1.4:
    Bedroom 2.1
  • rromeo923
    I almost always listen on shuffle so I liked to be surprised by what I hear next. So the more the better. I have so many files a good amount of them I have never heard. However on occasion if I want to hear a specific album and it isnt in the 20,000 I am out of luck. Oh well, the fact that I can even have this type of complaint is awesome. Love the technology.
  • rromeo923
    I found a server/player called Subsonic that seems to fit the bill for now. Check it out. It has some cool features allowing you to share any and all of your digital music collection and videos/movies etc. To access these features it cost $1 a month. Actually it is free to try for first 30days. The program itself is free.
  • If you want to move playlist from spotify to deezer or vice versa then use Musconvtool which i personally tried. It’s a great tool.
