Looking for a center speaker
trelytarms
Just bought the monitor 75t and am looking for a good center to match them.
Thanks in advance for any help.
Post edited by trelytarms on
I would thing the csi a6 would do just fineMy New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
CSI A6 IS NOT THE SPEAKER for your 75t .
The 25C or 20 is the correct speaker.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290281POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
Located in Alberta, Canada. Cant find a 25c is there another one that would match?
C15 is too small, don't even think about it.HT SYSTEM-
lsi 9's -
Can you buy off Ebay? You need a speaker with the two mid bass like your 75t
what about this?
http://www.ebay.com/itm/Polk-Audio-CS2-CHERRY-Series-II-Center-Channel-Speaker-NEW/231156204381?_trksid=p2045573.c100034.m2102&_trkparms=aid%3D555012%26algo%3DPW.MBE%26ao%3D1%26asc%3D20131003150253%26meid%3D4872627659816892542%26pid%3D100034%26prg%3D20131003150253%26rk%3D0%26rkt%3D8%26sd%3D390764355349trelytarms wrote: »Located in Alberta, Canada. Cant find a 25c is there another one that would match?POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
