What would cause this buzz?
Pycroft
Pycroft Posts: 1,960
edited February 2014 in 2 Channel Audio
Hi all,
I have listened to my new Musical Fidelity m6i integrated, and am loving it. Up until now I have only listened to cDs and no problems. Today I tried a movie. I have my avr pre outs connected to the aux/ht switch on the amp. There is a switch that can make it an aux input, or ht which would bypass the volume control on the amp. When I first tried, there was a buzz once I switched to the ht setting. I turned the bd player, avr, etc. off, and when in switched to the aux/ht setting, it buzzed again. I then moved the switch to the aux setting, and it does not buzz. I'm not sure if this is a problem with the unit, or if there is something I should try.
Tanks in advance for any input/advice.
James
2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player
Post edited by Pycroft on
  • Moose68Bash
    Moose68Bash Posts: 3,843
    I once had a similar problem.
    It was a ground loop. The only way I got rid of it was by using an optical digital connection between my VCR/DVD player and the preamp. No direct electrical connection between the components. I was told that it is a common problem when a TV setup has a cable connection.
    But, I'm no expert. I'm sure others on the Forum can give you more and better comments.
  • Pycroft
    I had a ground loop issue once before in another home. I assumed that this wasn't the case here since I have no buzz when playing CDs. Maybe im wrong?
    James
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
    treitz3 Posts: 19,195
    Hello James, do you have a cable box or satellite dish hooked up?
  • Pycroft
    I have an RCN cable box, but it's plugged directly into the tv, not the audio system. Only thing into the amp is the cd, and avr.
    James
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
    Okay, let's clarify a bit. Is there any cable or IC that connects the RCN cable box to the audio system at all? Even a shared outlet.
    Help me to help you.....what exactly is an RCN cable box?
    txcoastal1 Posts: 13,318
    treitz3 wrote: »
    Just a cable box...like comcast or TW
    Thank you, txcoastal1. So Pycroft, is there any cable or IC that connects the cable box to the audio system at all? Even a shared outlet.
    tonyb Posts: 33,001
    Any audio cable connecting any other piece of gear can transfer the buzz. That's why ground loops are so hard to track down.
    First decide if it's the amp, with the amp plugged in and speakers attached and the HT pass thru engaged, nothing else connected, no avr or cdp or tv/cable box....is there still a buzz ? If not, the problem lies elsewhere. Whats everything plugged into ? PC...One wall outlet ? Cables good ?
    You can try a cheater plug on the AVR, or try another set of analog cables going from the receiver to the HT pass on the MF.
  • Pycroft
    There is an HDMI wire that goes straight to the tv and does not go to the audio. The cable box is plugged into my monster power conditioner, which is plugged into the same outlet as the amp, which goes directly into the wall. This was the same setup I had for a different amp, and no problems before this.
    RCN is the cable company :-)
    Thanks for the help
    Jmes
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
    txcoastal1 wrote: »
    +1, RCN is one of the local providers of programming in that area.
    cnh
    I think treitz3 is on the right track. I've had different equipment hooked up to the same outlet as my TV and cable and on some, no problem. But when I hooked up the Nakamichi pre-amp below it went berserk, had to put a cheater plug on it to stop the noise. BTW the Nak was a NOS piece of equipment, a back up, never used by the original owner on Audiogon. Pristine, not a mark on it.
    cnh
  • Pycroft
    Problem found - thanks.
    Didn't know you could have a ground loop that affected one piece of equipment and not another.
    James
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
  • Zentish
    Zentish Posts: 127
    Ground loops seem strange until you understand them.
    If the incoming cable is at a different ground potential than the local home power, then there's basically a current flow between them. The current flow causes the hum in your system. Any copper interconnects can cause equipment to be affected by the ground loop. You will likely find that equipment with only 2 prong power connectors is unaffected, and equipment with 3-prong grounded power is affected.
    You can test this by performing "ground isolation" or "lift the ground" test: disconnect the outlet power ground from all your gear with a 2 to 3 prong adapter - you should not hear the buzz any longer.
    It's not recommended to leave your gear un-grounded though. Once you know what it is there are some remedies, including calling the cable company and complaining that there's a ground loop in the line that they need to fix in your neighborhood.
    Receiver: ONKYO TX-NR929 7.1 AVR 130wpc
    Mains: 2x Polk RTA 8TL's
    Center: Polk CS245i
    Surrounds: 2x Klipsch RS-41ii (because they fit perfectly over the door and window)
    Rear Surr: 2x Polk M4a '90
    Subwoofer: Speakerlab DAS-SW dual-voice-coil 10" '88 30Hz-150Hz
    Subwoofer Amp: ONKYO A-8019 AMP '85 100wpc
    Display: Samsung 55" UNC55-8000 3D LED
    Console: Xbox360
    DVR: custom MythTV rig w/ 3 tuners OTA
    Zone2: 2x Polk M5b '87
  • Msabot1
    Msabot1 Posts: 2,098
    A lot of those CATV companies think that ground is something you grow a garden in...good luck trying to explain a ground loop issue to them...
    tonyb Posts: 33,001
    Pycroft wrote: »
    James
    So...what was it ? Dead cat wrapped around a power cord ?
