Difference TSi200 vs RTi A3
jeto
jeto Posts: 17
edited February 2014 in Speakers
So can anyone tell me the difference? Specs look the same, same tweeter, TSi has one more mid/woofer. Thanks
    Those TWEETERS are different. The Rti tweeter has a different motor structure and is harder to clip, can handle more power, etc. And a more extended top end range as well as providing more "detail" than the TSI tweeter.
    cnh
  • jeto
    jeto Posts: 17
    Thanks, that explains the higher price, going with the RTi. Appreciate the input.
  • mr2686
    mr2686 Posts: 52
    You'll be very happy with the A3. It's worth the extra dough.
  • hnash53
    I did not experience the RTi A3's this way. I found the TSi200's to have a better, livelier sound. I A/B'd them using a Niles Speaker Selection switch so I could sit in my chair and flip back and forth between the two pairs of speakers while listening to the same song playing. And I found that, at least to my ears, the 200's sounded "better" to me.
    Of course, this is my opinion. Trust your own ears.
    "Is it sirius?"
