Speaker discharge
Jhayman
Jhayman Posts: 1,548
edited February 2014 in Speakers
I'm not sure what you call it but when I power off my Amp I guess after all the stored power discharges all the drivers in my 3.1TL's get sucked in then release back out..
I'm just wondering what is the cause of this?
I believe the single BIG woofer goes the opposite way to the mid-drivers..
Every other speaker I have owned never did this..
Post edited by Jhayman on
    treitz3 Posts: 19,950
    Jhayman wrote: »
    Your amplifier dissipating stored energy via the resistance of the speakers.
    F1nut Posts: 51,685
    Yeah, that shouldn't happen. No mute relays in the amp?
    tonyb Posts: 33,066
    Didn't you just have the amp worked on ?
  • Jhayman
    It does not make any noise or anything it's very quiet and seems gentle when this happens ..
    My Paradigms never did this before and after the amp repair..
    F1nut Posts: 51,685
    I'd contact McCormack to inquire if your amp has mute relays and double check that is common ground.
  • Jhayman
    Ok Thanks guys I'll check with McCormack..
  • NJPOLKER
    NJPOLKER Posts: 3,474
    For some sick reason when I read discharge I thought of yeast LMAO
