DSWPRO660wi or DSWmicroPRO 1000?
i bought a DSW microPro 1000 SW (8 inch, 1200W) and i think is really nice but i doubt if change it to DSW Pro 660 wi (12 inch, 400W). i have two days to decide it.
With music i think it´s not necessary with my LSi9 speakers but with movies I raise the volume much to feel and fill the room. My room is 18x14 size.
any opinion or experience?
thanks in advanced
edit: the DSW PRO 660 wi it costs about $80 more than DSW microPRO 1000.
thanks in advanced
Sony DA2400ES
LSi9 - LSiC -LSi7
SW 660wi 12´´
LSi9 - LSiC -LSi7
SW 660wi 12´´
Post edited by inbox on
Welcome to Club Polk,
What a coincidence, I am in the same boat as you, looking at exactly the same 2 sub-woofers with the same room size lol.
I'll be keeping a watch on this thread. -
Thanks ThirdWorldGuy!
any opinion?Sony DA2400ES
LSi9 - LSiC -LSi7
SW 660wi 12´´ -
Obviously the best idea is to try out both and then decide. If that is not possible, and you are not using the sub for music, then I think the DSW is clearly the better choice on paper. Bigger woofer, ported, its going to be deeper, louder, and hit harder for movies. The difference is the bass will probably not be as tight as the micropro and might not integrate quite as well. But this is all academic as I have never heard them. So like I said, get them both and eat the refund fee, the assurance you have in the end will be worth the small price.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
thank you very rooftop59 I especially appreciate your helpSony DA2400ES
LSi9 - LSiC -LSi7
SW 660wi 12´´ -
Finally i returned the DSWmicroPRO 1000 SW (8´´) (I had greatly increase the volume of the SW to "feel" it and fill about 75% the room) but i think it´s great. Now I'm thinking to buy a DSWPRO660wi (12´´)
I have LSi9/LSi7 speakers and my room is 18x14 size. I will use the SW for music (30%) and movies (70%) of time.
what about DSW 660pro wi? any experience with it or any alternative?
thanks in advancedSony DA2400ES
LSi9 - LSiC -LSi7
SW 660wi 12´´
