Another Bi-amp question
jeremymarcinko
jeremymarcinko Posts: 3,785
edited February 2014 in 2 Channel Audio
Is it okay to bi-amp my rti's with my receiver and the power amp? Say, let the receiver power the top half and the power amp, power the lower. I would be using the L,R speaker out and L,R pre-amp out at the same time.
I understand this to be passive bi-amping and not the best method of bi-amping, but I am in the mood to do some tinkering. I just don't want to break anything.
Another thought. Probably another bad idea, but what if I treat the lower half of the rti 12's as subwoofers, and connect the power amp to the subwoofer outs of the receiver? I could set the crossover fairly high 120- 140 hz.
Being that the rti'12 is an 8 ohm loudspeaker, would passive bi-amp create a 4 ohm situation? My thinking separating the upper from the lower would also cut the resistance in half.
Post edited by jeremymarcinko on
  • zeppage2
    zeppage2 Posts: 196
    remove jumpers first
  • aboroth00
    aboroth00 Posts: 1,106
    It's usually ideal to use the same amp to drive the top and bottom halves to make sure the top and bottom halves are driven equally, i.e. to the same volumes.
    As for driving the subwoofer outs of the receiver, if the crossover point of the woofers is let's say 500hz and you only feed the woofers 120hz and below, you'll be missing out on some bass information which won't be ideal. I would bet the woofers drive a bigger portion of the bass region and thus it's not recommended to do such a thing.
    You will not create a 4ohm situation unless you wire two speakers in parallel, you connect two speakers to the same amp taps.
    If you want to do some tickering you can always play around with adding and tweaking a sub. Do some RTA.
    2Ch Tube Audio Convert
  • jeremymarcinko
    Yeah, I have no desire to add a subwoofer at this time. I had just moved from a 7.2 surround system consisting of Monitor70's, 50's,40's cs2 and two klipsch sub10's. My interest is purely two channel music at this point. I sold the Polk monitor/klipsch gear about a month ago and purchased the new Rti's from polk's ebay store. My intentions were to simplify things with two large towers for music, I do not watch many movies right now. The Rti's sound really nice with just the ATI even though it is only rated at 120 wpc. I do think there would be some benefit to adding a larger amp and I plan to at some point.
    I am just in the mood to play a bit with the setup. I didn't want to damage anything by using the pre-outs and speaker outs simultaneously. I was thinking the bottom end crossover was around 120hz on the 12's, which led to the idea that the sub-outs would cover the spectrum.
    As far as level matching, wouldn't the audyssey program take care of that, with the eq?
    My biggest concern was that I would be putting a 4 ohm load on my receiver, but if thats not going to happen I probably give it a go, I have some free time today.
    F1nut Posts: 51,687
    Can't do that.
  • aboroth00
    Audyssey won't take care of that. With different amps with different input sensitivities, they'll put out a different amount of wattage at any particular volume setting. So it's generally recommended you use identical amps to drive biamped speakers. As you mentioned earlier, passive biamping especially with a receiver when the amp is more than capable of driving the speakers is mostly moot. If you want to do just 2ch, perhaps a dedicated 2ch preamp is in your future?
  • jeremymarcinko
    Your right, a Pre-amp and larger Power amp is in the foreseeable future, but for now I have the avr. I see what your saying about the amps having different outputs, that makes sense. The specs show the Rti's Subwoofer Crossover at 120Hz, 12dB/octave low pass. It seems to me that in this case it is almost like setting up a couple of passive subwoofers with an external amp, as the vast majority of the FR is being directed to the upper half. I think I can get the levels close. As I mentioned I am just playing around here, as long as I don't break anything I will be happy.
    tonyb Posts: 33,067
    Might want to call Polk CS and order replacement drivers now....that way they'll be on hand.LOL
  • jeremymarcinko
    Yeah, I think I read somewhere the warranty does cover ignorance.
  • jeremymarcinko
    Can't do that.
    Okay if I can't do that, then I wonder if I set the receiver to bi-amp, will the surround back pre-outs carry the L,R signal.
    I have some things to try.
    tonyb Posts: 33,067
    Yeah, you can do that but your still not gaining anything. Your still using the same amp in the receiver which in biamp mode uses all 7 channels, thus robbing some power from the other ones.
