Needing help with PA660.4 amp settings
Powerslave
Hi. Thanks for reading this.
I have a PA660.4 4 channel amp powering 4 kicker cs65 6.5 speakers. My HU is a Sony BT4100P. I have no sub at this stage. I am not sure if my amp should be set to "full" or "HPF" for my speakers. Also, I would like to use my HU for the frequency and not the amp's crossovers. As my amp does not have the option to turn off the crossovers, I am not sure what to set them at to use the HU crossover. Do I turn them all the way down? to 50 hz? or all the way up to 500 hz? Or do I put my amps crossovers to "FULL" and use the HU crosssovers?
Thanks for your help as I could not find any info in the search for this.
Post edited by Powerslave on
Since you dont have a sub, just leave them all set to FULL. Once you get a sub, youll probably want to cut them off a little higher like 63 Hz or so.polkaudio sound quality competitor since 2005
I have a pa 660 i need help to figure why it keeps goint to protect mode would u kno n help guide me fix this issue please J78014921@gmail.com
