CSi40 power port damage, HELP
JohnRockets
Hello all,
This past weekend my CSi40 took a short fall and one of the powerports is now cracked and missing a good chunk (the cone is still there but a good chunk of the flat part on one side is gone). The speaker itself sounds fine and looks fine except for this. Is there any way I can replace this one power port? Is it even worth the hassle? If so how? It looks like I will have to remove one of the drivers to release/fasten from the inside, right?
Please help.. thanks
I just had to replace one of those things in an RTi38 because it was an open box with an apparent broken port. You have to get the short little nub screw drivers to do the unscrewing. Yes, you will have to replace the drivers in order to get to the port, and you have to be careful not to dislodge the port itself from the inside. It's all about patience......comment comment comment comment. bitchy.
