DH Labs/Luminous Audio RCA Cables
zingo
zingo Posts: 11,258
edited February 2014 in For Sale (FS) Classifieds
These are two custom built pairs of DH Labs White Lightening cable with Luminous Audio Silver Locking RCA plugs. One pair is 3ft 2in and the other is 4ft 2in in length. They were soldered with Cardas Quad Eutectic and are fantastic unbalanced cables.
$50 per pair plus shipping
Post edited by zingo on
  • zingo
    zingo Posts: 11,258
    These are my favorite RCA plugs by far and I'm building my new (shorter) cables with them as well!
  • zingo
    zingo Posts: 11,258
    Locking silver-plated RCA connectors: Luminous Audio is proud to introduce an affordable "locking" style RCA connector of very high quality with heavy silver plating. Each plug is made of a very inferior quality brass which is mixed with many other metals and impurities with poor conductivity on purpose. This allows the signal flow to remain primarily in the heavy silver plating preserving the integrity of your music. The plug can be used with a 6mm or smaller cable with the addition of a heat shrink boot but is designed to work with a cable of 8mm OD. Soldering of the return lead or shield should be done in the lower section of the plug away from the center pin if possible. The plug should be inserted into a jack in a loose position and then "tightened" by simply turning the outer barrel counter-clockwise with respect to the rear of the plug. Happy listening!
  • zingo
    zingo Posts: 11,258
    3ft 2in pair SOLD
  • zingo
    zingo Posts: 11,258
    4ft 2in pair still available
  • seabeerob213
    seabeerob213 Posts: 1,843
    PM incoming
  • zingo
    zingo Posts: 11,258
  • seabeerob213
    thanks for the great deal on some hopefully great cables Z-man, pleasure doing business with you
  • zingo
    zingo Posts: 11,258
