SVS PC12-NSD vs PC12-Plus
falconcry72
falconcry72 Posts: 3,580
edited February 2014 in Speakers
I've been running a pair of PC12-NSDs in my HT system for almost a year now. They kick some major butt, but I am thinking about upgrading to the Pluses. I bought these new from SVS, so I am eligble for SVS's upgrade program... I can trade in the NSD's and get my full original purchase price credited towards the cost of the Pluses. After shipping etc, the move would cost about 900 bucks, and then the clock resets so I'll have another year to decide if I want to upgrade to the Ultras. I have 17 days to make the decision...
Based on specs alone, it seems that there is a much bigger performance jump between the NSDs and the Pluses than there is between the Pluses and the Ultras, so I'm thinking this could be a wise jump.
Anybody have experience with both models?
Post edited by falconcry72 on
  • aboroth00
    aboroth00 Posts: 1,107
    I've owned the PB version of the NSD and the PC version of the Plus. The Plus is a nice step up in sound quality. You get the ability to tune the subwoofer using port plugs to your liking. However, output wise the Plus's aren't heads and heels over the NSD. You get slightly more amp power, a better driver, but it's still the same size 12". In the sub world considering the subs are relatively equal, the bigger the better. There are a lot of players in the ID world that I'm not as familiar with anymore and in all honesty, I can't tell you what's best value-wise.
    2Ch Tube Audio Convert
    Toolfan66 Posts: 18,217
    Funny, I was just on their website looking at the plus this morning.. I see myself pulling the trigger on it soon..
  • falconcry72
    aboroth00 wrote: »
    ...The Plus is a nice step up in sound quality. You get the ability to tune the subwoofer using port plugs to your liking. However, output wise the Plus's aren't heads and heels over the NSD....
    Yea, I don't really need a whole lot more output than what the NSDs provide, but I would certainly appreciate lower extension and generally better musicality in terms of tone and speed.
    Did you find the Plus driver to be more musical than the NSD driver?
  • falconcry72
    Toolfan66 wrote: »
    Nice. I think the NSD offers incredible bang for the buck, but I am very tempted by the Plus. I'll probably cave and pull the trigger.
  • ken brydson
    ken brydson Posts: 9,037
    My input even though I have no experience with the NSD models. I've had a 25-31PC+ for years and love it. When I first got it I tried plugging a port and running in 20hz mode and felt like it struggled. SVS offered a driver upgrade to the 12.3 model for cheap. BIG difference.
  • WLDock
    WLDock Posts: 3,073
    $900 to swap them out. Maybe keep what you have and go Quads via DIY?
    2 x Stereo Integrity HT 18" = $324
    2 x DIY Sound Group 4 cu ft sealed flatpack = $240
    1 - Peavey IPR2 2000 = $350
    1 - MiniDSP Balanced =$125
    1 - UMIK-1 USB measurement mic = $75
    1 - R.E.W. software = free
    = $1114 + what else one might need.
    Data
    http://www.data-bass.com/data?page=driver&id=46
    http://www.data-bass.com/data?page=system&id=90
    One such build
    http://www.hometheatershack.com/forums/sealed-subwoofer-build-projects/64052-stereo-integrity-ht-18d2-build.html
  • aboroth00
    DIY is always going to be the best bang for the buck.
    When I think of the NSD, I think HT sub. It's a great bang for your buck sub and it was one of the subs that really got me started into HT subs. It can belt out SPL and keep chugging. However, for music, the Plus overall is a better sub. Much more musical, faster, and overall more coherent. It's a nice step up from the NSD. After all, the NSD is an entry level sub.
  • rpf65
    rpf65 Posts: 2,127
    If you're happy with the subs you have, keep them. If you were considering the 13 ultra, that would probably be something to think about.
  • falconcry72
    Thanks for the input, Ken. One thing that is so attractive about SVS is their customer service/trade-up policy/bill of rights.
    Your experience is what makes me think that the Plus driver really is superior to the NSD driver.
  • falconcry72
    WLDock wrote: »
    Data
    One such build
    Wish I had the time. I need a simpler solution.
  • falconcry72
    aboroth00 wrote: »
    ...for music, the Plus overall is a better sub. Much more musical, faster, and overall more coherent. It's a nice step up from the NSD...
    You may have just sold me, my friend... if it doesn't work out, I'm sending you a bill :)
  • falconcry72
    rpf65 wrote: »
    See, I was thinking that there was a bigger difference in performance between the NSD and the Plus than between the Plus and the Ultra, reagrdless of the driver sizes... have you found that to not be true?
  • WLDock
    WLDock Posts: 3,073
    Sounds like you really need to consider all options? Maybe dual sealed is what you are after? Maybe a not normally recommended mix of one Ultra and NSD? Or maybe some other brand? Two ULS-15's?
