The HT Project is close to complete.
gudnoyez
Well the HT project is close to being complete the walls floors are done, had to give up half the man cave the wife wants the HT portion kinda how to say less bar room style a little painting, finishing up the laundry room. The good news the other half of the cave is to do as I please which will be the bar, the pub table, 2 channel then the back bedroom will be another 2 Channel room, lots of work to do.
The HT Furniture showed up the other day 5 piece, and of course my Oppo 105D will leave everything packed as of now because of the painting, but will probably bust the Oppo out and hook it up to my Adcom and 2B's and give her a good test drive and check out all the new SACD's I have acquired as of late, will post pics when the project is done, thanks to all of the inspiration fellow Polkiies
Having trouble sleeping, Steve? "Excited as a kid in a candy store!" comes to mind. Have fun and shoot some pics along the way to post later.
Are you gonna have anything ready by Super Bowl time, or is this more of a drawn-out project? -
Good job Steve! Now get that project finished and get some,tunes playing.mif you bust out the Oppo you won't get much work done!Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
Any pics you want to share
Its always good to see others examples..."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
The basement got flooded out last spring lots of basements not just mine. we had a late 13 inch snowfall last march 2 days later it got in the 60's melted everything, then we got 8 inches of rain on top of that. Lots of basements flooded around here, my sump pump could not keep up. I gutted the basement and had to wait till late November to have drain tile installed.
They were that backed up so I have been on this project for a while its close to being done so me and the wife decided to put the main HT down stairs and decided to upgrade the rig. Its been a long project the worst part was cleaning up after the drain tile was installed the concrete dust was everywhere. I will soon be able to enjoy the cave again the HT will go in the back room where the gray carpet was installed the 2 channel on the tile side. I cant wait to be finished its been a project for sure.Home Theater
