Tonight
EndersShadow
EndersShadow Posts: 17,596
edited January 2014 in 2 Channel Audio
I am in audio Heaven!
MrBirons DacMagic w/ Pangea PSU arrived. He included a set of Aural Thrills RCA's which I will try out later. I quickly hooked up the BlackCat Coaxial cable I got from Pearsall01 to the DacMagic from my computer, selected a 96hz playback rate and connected Dougs IC's to the DAC and my Sunfire.
Pulled out my Harmony One, hit FLAC to select the right input, opened up XBMC, ran down to Simon and Garfunkle and queued up Sound of Silence, Mrs Robinson, Bridge over Troubled Water & Scarborough Fair..
The music started, my jaw hit the floor and I splooged all over myself and my gear.
Excuse me while I go get a towel.
Post edited by EndersShadow on
  • Jhayman
    Jhayman Posts: 1,548
    edited January 2014
    Rofl, splooged myself....:lol:
    txcoastal1 Posts: 13,318
    edited January 2014
    Well I hope you enjoy your new gear because the value just bottomed out because...
  • Conradicles
    Conradicles Posts: 6,130
    edited January 2014
    Nice! What component made the big impact?
    edited January 2014
    DSkip wrote: »
    This has me rethinking buying that audio gd off you....
    LOL. Skip, I used that at work. No splooging there.....
    SCompRacer Posts: 8,511
    edited January 2014
    So more folks are concerned about Dan splooging than what he's listening too? I mean, yeah, I grew up with and like S & G, but Dan...... lol j/k
    Kewl! Glad you are enjoying the new stuff!
    edited January 2014
    SCompRacer wrote: »
    Yeah, I know its not Gagasta Rap (dont tell Dave)
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited January 2014
    Glad it's working well for you. Speaking of splooging where the hell has Rick88 been and the redhead pics? Somebody needs to do a welfare check on him, lol.
    nooshinjohn Posts: 25,461
    edited January 2014
    Dan might be selling some speakers later...
    tonyb Posts: 33,001
    edited January 2014
    For God's sake man, clean yourself up. Don't let the kids see you like that, may damage them for life. LOL
    Glad your digging it, I'm a big fan of that Black cat digital cable btw. You did good.
  • dromunds
    dromunds Posts: 10,023
    edited January 2014
    And you were giving me grief for blowing my wad on tubes....
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    edited January 2014
    Enjoy your new goods,but you gotta quit telling folks what happens in private.
    tonyb Posts: 33,001
    edited January 2014
    Someone remind me to never shake Dan's hand....ever !
  • falconcry72
    falconcry72 Posts: 3,580
    edited January 2014
    So you're using SPDIF out of your PC, not USB?
    edited January 2014
    Yes for right now. The USB device only showed a setting of 16/48.0 as an export option. The Coaxial allows for a 16/96hz incoming sample rate, and I figured higher was better. I know the DAC upsamples, but I figured if the signal was better coming in, it would be better coming out.
    Also the USB had some noise in it somehow it sounded like. I didn't mess with it much, I like the coaxial cable quite a bit, so I used it.
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited January 2014
    SMFH, No more Simon and Garfunkel for you. "Jesus loves you more than you will know..whoa..whoa..whoa...eww.eww..eww".
    edited January 2014
    If there is no isolation between device and computer, you can get noise from 'putie using USB. I've had it go both ways with non-isolated USB devices. That is quiet and some noise added.
    Mrs. Robinson, great song.
    edited January 2014
    SCompRacer wrote: »
    How would I know if its isolated or not? I am drawing a blank today.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited January 2014
    That's the great thing about audio, that we can all listen and hear or prefer different things. I didn't really like the DacMagic very much when I tested it in the DAC shootout. In fact, I've never really liked the Wolfson chips that much (yeah I know the chip isn't everything), as they tend to be a little too laid back and not detailed enough for my taste.
    edited January 2014
    It should appear in the specs. Isolation can be in form of 1:1 transformer or a chip.
    The idea being that you use the DAC's power supply to power the USB input (not the computers power supply through USB cable) and no ground connection exists between the DAC and external device occurs.
    When you were here, if I played music from my laptop to my diy DAC, that USB to I2S adapter had no isolation and had zero noise. I did nip the USB power wire and do power my USB module via a power supply in the DAC. However a ground connection does exist with the 'putie via the signal side with my current module.
  • TNHNDYMAN
    edited January 2014
    ^ yeah what he said....jeez Dan get some coffee or something and use that noggin.
    Yes the above is well beyond my knowledge. Understand the intent but the implementation forget about it.
