no mix and matching
leftwinger57
leftwinger57 Posts: 2,917
edited January 2014 in Vintage Speakers
I d/l the generic instruction manual for SDA speakers.The manual covers 1c, SDA2b, CRS+. On page 2 there is a really bold printed paragraph that says "IT IS IMPERATIVE THAT CURRENT VERSIONS OF THE SDAs NEVER BE CONNECTED TO PREVIOUS VERSIONS OF THE SAME MODEL". It goes on and says if you do you risk damage to your amplifier and both speakers and covers the common ground issue. Wow ,not that I'm changing anything but why are these not interchangeable if the same model type. So lets say I'm robbed and they only had time to get 1 of my 2Bs I cannot just get any other 2b it has to be same year or else? This I never heard of before and I think this info should be out there somehow and not just in the manual you would get if bought new. Also if selling on e-bay and the guy says yes I have a left and right set but not tested don't have stuff blah blah how could you know your getting a correct matched set or not.
  • Schurkey
    Schurkey Posts: 2,122
    edited January 2014
    First Guess: Previous version of same model means you can't make a set of two speakers using one 1C and one 1B, 1A, or 1.
    One 2B can't be mated with one 2A or 2.
    Polk never did sell sequential-serial-number speakers, so if you have a left and a right 2B, or 1C, or whatever, you're all set, even if they weren't sold as a "pair" originally.
    Minor caveat if one of your speakers is an early-production 1C or 2B that used the blade/blade SDA jack and one of them is the later pin/blade: You'd have to update the wiring and jack of one or both speakers so an SDA cable can be connected.
  • boston1450
    boston1450 Posts: 7,758
    edited January 2014
    ^^^^ +1 makes sense..Leave a note for the robber stating they must take both OR none at all :smile: joke
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • boston1450
    edited January 2014
    I would think the SDA earlier versions has different crossovers in them-in even that model possibly-interesting read LW
    Randy-Maine
    by David WMG
    F1nut Posts: 51,771
    edited January 2014
    The previous versions mentioned are blade/blade and you cannot connect a blade/blade SDA to a pin/blade SDA due to the way the crossovers are configured.
  • leftwinger57
    edited January 2014
    So Jesse it doesn't matter year made or generation as long as i/c is the same w/ mine being blade/blade originally and of course the side that is needed? May they be spiked to crap if ever someone tries to take my 2Bs. I put a lot of work into those puppies.All hypothetical of course.
    F1nut Posts: 51,771
    edited January 2014
    Well, I wouldn't use a 3.1TL on one side and a 2.3TL on the other, just isn't going to sound right and the difference in crossovers would likely cause a problem.
