adcom 5400 vs 5500
RodneyWoodford
RodneyWoodford Posts: 144
edited February 2014 in Electronics
I'm running my RTi10's now with an Adcom 5400 120 watts per channel. Would I see a big improvement by getting a Adcom 5500 200 watts per channel. Any suggestions? Thanks for any info. I'm using an Harman Kardon 254 to run the center and surrounds , sub.
Post edited by RodneyWoodford on
  • VCoak
    VCoak Posts: 200
    I run a 5500 on stock 1.2's (for now). The big girls eat my adcom up if go past the 3 o'clock. I've had no problems with 5500 and use it daily and even left her on for days. Probably not a got idea. Never used the 5400. Some ok prices on the 5500. Watchout for one on audiogon right now. Looks like the heat sink fins got cooked. Good luck
    W4S SX-1000, Adcom gfp-750, Polk 1.2tl, W4S DAC 2 DSDse, 2012 mac mini (mod), JRivers ver. 19, WD Cloud NAS 2 t.b., Monster Cable AVS-2000 signature, Doug's Alpha I/C & Doug's biwire 6' speaker cables
  • lanchile
    lanchile Posts: 560
    if you can get the Adcom 5500 at a fair price...get it! Those Adcom amplifiers were build like tanks and sound really good. if you like
    loud music and need the "extra"power, get the 5500 other way save some money and get the Adcom 5400.
    Make it simple...Make it better!
  • jersmith
    jersmith Posts: 11
    Good luck with the amp. I have 5500 that I bought a few months ago. Have not compared it to any other Adcom amp though.
  • Devlon
    Devlon Posts: 355
    Hey Rodney, I too am using a AVR 254 as a pre/pro with my Adcom GFA-7500 amp. I noticed a significant difference in the low end on my Lsi's when I biamped. I use four of the Adcom's 5 channels to bi-amp my front two speakers. The 5th channel of the Adcom powers my center speaker. This way I have matching power and specs for the most important speakers, the front 3. The HK's own power powers the surrounds. The GFA-7500 pushes 150 wpc into 8 ohms, and 225 wpc into 4 ohms. These are really great amps.
    Living Room: HK AVR 354 as pre/pro, 2 x Polk Audio Micropro 4000, Adcom GFA-7500, 2 x Mirage OMD-15
    2 x Mirage OMD-5, 1 x Mirage OMD-C1, APC H15, Sony S790, Philips 52" LCD, Beogram 3000, FAT (Firestone Audio Tobby DAC), Harmony One
    Den: Sherwood R-972,as pre/pro, 2 x Velodyne SPL-1000R, 3 x Crown Drivecore XLS1500, 2 x Polk Audio Lsi9
    1 x Polk Audio Lsic, 2 x Polk Audio Lsifx, Sony S790, APC H15, Dspeaker Dual Core 2.0, W4S DAC 2, Keces DA-151
