SDA SRS 3.1 TL listening impressions
polklifer
Well I got the SRS 3.1 TL's put back together with Larry's rings, Dynamat, Sonicaps/Solen crossover upgrade, RDO-198 tweeters and a shiny new IC cable with Speakon connectors. Hooked it to a H/K Citation 22/B&K Reference 50 pre...playing tunes from an AudioRequest music server..
Started with some pipe organ music on Telarc, left this on and went to the grocery store for a couple of hours, left it a medium vol.
Que up some Frank Sinatra, and let the magic start...WoW
Everything is better sonically, bass has actual harmony now that I couldn't hear before, the same goes for the mids, subtile changes to the good for sure. The tweeters are the gem of the show, a little veiled out of the box, but after a few hours of listening, they just keep getting better and better...very, very smooth, awesome in every way!
All of the little tweeks combined together really launch this speaker into the stratosphere of nervonna for me anyways...I am going to start on the Dreadnaught cable here soon.
If you are on the fence as far as doing the upgrades, get off it...these mods really do the job!
Thank you all for your input and advice, you guys are the best!
Post edited by polklifer on
The 3.1's are a gem, enjoy your handy work, they will only get better with time.
