Opinions on Carver preamps?
xfontanax
xfontanax Posts: 82
edited February 2004 in Electronics
In my bedroom rig, I have a carver M1.5t w/C-2 pre and LSi9. The source is denon dcd-1520 w/a denon da-500 dac. I've been really happy with this setup, until I picked up a yamaha dsp-a2070 for $10. WIth the same source, the yamaha has a much warmer sound. The mids are smoother, and the bottom is fuller.
I have to admit, the yamaha sounds really good, and just might push the carver gear out of the room.
I think the weak link in my setup is the C-2 preamp. For those familiar with carver preamps, how does the C-2 compare with the other carver preamps? Aside from the SH, will the C-1 give a better sound? How about the 4000? I don't want to "upgrade" my preamp to another carver, and get the same sound. How do you feel about carver gear compared to others used gear in the same price range(say $250 or less)?
Thanks, any advise/input would be appreciated.
Post edited by xfontanax on
  • George Grand
    George Grand Posts: 12,258
    edited January 2004
    The line-stage in the C-1 and C-2 are virtually the same. There is nothing wrong with the C-2 preamp. You have upgrade fever.
    George Grand (of the Jersey Grands)
  • Airplay355
    Airplay355 Posts: 4,298
    edited January 2004
    u sound like the school nurse....your throat is red from the juice u drank at lunch, you aren't sick, go back to class. lol
  • xfontanax
    xfontanax Posts: 82
    edited January 2004
    I thought that might be the case, but have never heard any other carver preamps. What about the 4000?
    And you're right, I do have upgrade fever.
  • TroyD
    TroyD Posts: 13,124
    I don't know about the 4000 however I'm going to go out on a limb and say it's probably no different from the C-1 or C-2
    Currently I have a C-16 that has two sets of outputs, one is voiced to sound like a solid state preamp (sounds identical to the C-1, far as I can tell) and one set that is supposed to sound like tubes, I don't know if it sounds like tubes but it sounds pretty darn good.
    IMO, as far as solid state goes, I haven't heard a pre (not that my experience is all that vast) that is better than the Carver.....you might investigate a tube preamp.
    Just a thought.
    BDT
