Next Issue
BKphoto
BKphoto Posts: 409
edited January 2014 in Vintage Speakers
The interconnect port on my new to me sda 2a's has a crack in it....am i up the river...?
Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
Post edited by BKphoto on
    pitdogg2 Posts: 25,722
    edited January 2014
    nope it should still work or you could replace with the Neutrik speakon connectors as many have done
  • BKphoto
    BKphoto Posts: 409
    edited January 2014
    thanks...
    edited January 2014
    just make sure you can tell there is friction on the blades. If not you may need to get inside to pull them out of the socket and pinch a little tighter for a firmer grip. I've had to do the same thing. I have never tried but you maybe able to just do it from the back just check and see with a very small screw driver. Be very careful as that plastic is old and brittle.
  • zane77
    zane77 Posts: 1,696
    edited January 2014
    Also make sure that the crack is not leaking air from inside the cabinet through it, the SDA's like to have a sealed cabinet.
    Two Channel
  • drumminman
    drumminman Posts: 3,396
    edited January 2014
    zane77 wrote: »
    +1 Air leaks diminish the bass response.
  • decal
    decal Posts: 3,205
    edited January 2014
    BKphoto wrote: »
  • BKphoto
    BKphoto Posts: 409
    edited January 2014
    Going to do all this but these are on the back burner....I'm restoring my monitor 10b's then next I'm restoring my hafler xl 280...going to fill it full of goodies from musical concepts...
    Then the sda's
