Sansui T-9 Tuner
VR3
Pros --
GREAT reception have some atenna tweaking
Metal construction -- very solid
Bright LED
Signal strength LEDs -- pretty useful
Very simple to use and setup
Cons --
YOU HAVE TO TWEAK THE ANTENNA, if something is not touching both ends of the antenna it picks up nothing but static, so I just wrapped the patch cables around it.
IT LOSES PRESETS!!! THIS IS AGGRIVATING!
3 foot power cord!
SOUNDS GREAT THOUGH! Very clear, me like!
Well worth 50 some bucks.
Bright LED
Cons --
3 foot power cord!
Post edited by VR3 on
Check the back unit to see it it takes batteries. Some of the old receivers and tuners used battery power to hold the memory of the AM/FM pre-sets. My Dad's old Sansui receiver used batteries for this.
It uses batteries...
They are uh.... *corroded* in there..?? lol
Thanks though --- that explained a whole lot!
The dude left the price tag on there -- he had bought it from a Pawn Shop in Raleigh. However -- he or someone else paid 130 for it!!! I paid 54 shipped...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
