Possible to fix SL2000 tweeter?
Mystery
I happened to stumble upon a pair of 7C's today and got it for $60.
It sounded okay but had one tweeter dome pushed in.
When I set them up at home, I noticed that tweeter is not sounding right.
Treble is there but it's not smooth and little off compared to the other good one.
I looked closer and saw whatever pushed the dome, it caused a small portion of that copper vc to come up slightly out.
I tried to push it in the gap but it's no use.
I guess time to replace? :sad:
I don't want to spend $100 for RDO on these so hunting time in the epay for single SL-2000.
Post edited by Mystery on
I'm assuming that BOTH tweets are bad (otherwise it wouldn't be $100). The fact is, you can buy a couple of SL-2000's (used) for $50+ or a couple of RDO-194's (new) for $100 AND they would sound better.
Your choice!Yamaha RX-A2050 AVR (5.0.2); LG OLED77C2 4K TV(4) Polk Monitor 10B's w/SoniCaps, Mills, and RDO-194 tweets (R/L F/R)(2) Polk RC80i (Top Middle)Polk CS300 center channelAnalog: B&O TX2 Turntable, Nakamichi Cassette Deck 1Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-RayBedroom: Arylic Up2Stream AMPv3 driving Polk Monitor 4's w/peerless tweets -
I have a replacement, and you don't live to far from me.. Sent you a PM..Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
Hope the tweeter worked out for you..
Nice to meet you, and nice to know you live right up the street!! LOL!!Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Haha that is funny. Lives right up the street! I was going to give him one if you did not. Good lookin' out Larry.
Larry,
Great to meet you finally and thanks for the generosity.
He didn't even take my money for the tweeter.
It turns out my new house is just few hundred yards from him.
We are neighborino like in Simpsons.
If he turns his 1.2TL's little high, I don't need to buy to enjoy them.
Anywho, 7C's work great but one side is significantly louder than the other so need to check what's going on.
Here is my temporary setup in basement.
If you're already swapped L/R on the amp, it's time to take that cross-over out for a closer examination. Whatever damaged the bad tweet may have originated further upstream...Yamaha RX-A2050 AVR (5.0.2); LG OLED77C2 4K TV(4) Polk Monitor 10B's w/SoniCaps, Mills, and RDO-194 tweets (R/L F/R)(2) Polk RC80i (Top Middle)Polk CS300 center channelAnalog: B&O TX2 Turntable, Nakamichi Cassette Deck 1Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-RayBedroom: Arylic Up2Stream AMPv3 driving Polk Monitor 4's w/peerless tweets -
I'm as dumb as a rock.
I had right side speaker out of 'B' set to a subwoofer and it was changing the volume of the right 7C since left out was not used.
:rolleyes:
All good now.
