RTA15tl , I need a pair of bookshelves to match it .
Dropthebeat
Dropthebeat Posts: 154
edited January 2014 in Speakers
What bookshelf speakers would match the sound of my rta15tl and 11tl ? I looked online but couldn't find any info
Yamaha V1800 receiver along with a NAD 2600a and 2700a .
Sda 1c - my new favorite speakers
Rta 8,11tl,15tl
Monitor 10 and 12
Marty sub 18" still in the works
Klipsch sw12-2
Hobbies turn into addictions .
Post edited by Dropthebeat on
  • Dropthebeat
    edited January 2014
    I've had a hard time coming across those . Atleast local that is.
    Rta 8,11tl,15tl
    Monitor 10 and 12
    Klipsch sw12-2
  • Dropthebeat
    edited January 2014
    I was hoping to find something smaller as well.
    Rta 8,11tl,15tl
    Monitor 10 and 12
    Klipsch sw12-2
  • skrol
    skrol Posts: 3,436
    edited January 2014
    You will want to have the tweeters fairly well matched. Have you swapped out the SL-3000 tweeters in your 15TL's and 11TL's for the RDO-198? If so, go for one of the monitors that had the SL-2000 or SL-2500 and swap the tweeters for the RDO-194 or, if possible, do the TL mod and go with the RDO-198.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Dropthebeat
    edited January 2014
    Yeah both my 11tl and 15 have the tweeters replaced with the rd0198 . Ilare the 4 and 5 monitors the smaller of the bunch ?
    Rta 8,11tl,15tl
    Monitor 10 and 12
    Klipsch sw12-2
  • boston1450
    boston1450 Posts: 7,758
    edited January 2014
    I use the Monitor 4's as rear channel. They are small & can be picked up for under 100.00 to your doorstep.
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    txcoastal1 Posts: 13,497
    edited January 2014
    There are several pairs of Mon 4's Craigslist ads posted on http://www.hifishark.com/ just type in Polk monitor 4 in search box select U.S.
