Not familiar with their products
rpf65
I'm currently in the process of remodeling my living room, specifically for my HT system. Guess that's the best term, remodeling, but probably a little over kill. Anyway, one of my future upgrades will be a better AVR. Looking into Pioneer SC series, and these are much bigger than the entry level Yamaha I currently have.
Because of the height of the Pioneer, I may have to eliminate the center shelf of the stand I'm currently using. Not really a big issue, but like the way this particular stand looks, and should still have enough room for the upgrades, if I move the center channel speaker somewhere other than on the stand.
While looking for speakers mounts, which is another question I have, I ran across a component wall mount, made by Peerless. The model PS200 to be precise. The site says it will support 100 pounds, and figure I'll order a custom piece of glass for a shelf, and simple put the center speaker there.
My question is, does Peerless make a decent product, or should I look else where?
I'd also like advise on speaker mount?. I'll be mounting RTI A1's as front highs, so the would have to be able to tilt both horizontal and vertical.
Thanks for any advise in advance.
Yes peerless has been around for a long time. I use there TV mount products regularly2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
