Dac?
Pycroft
Pycroft Posts: 1,960
edited January 2014 in 2 Channel Audio
Hi all,
Does a DAC only improve sound quality if you are using a computer setup? I've never seen a DAC, so not sure how they work, but does it improve music played through a CD or SACD player? I'm asking because I'm looking at high quality integrated amps, and some have DAC's built in, and I'm not sure if that's something I even need. I have no interest in making a computer based system, just CD's :)
James
2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player
Post edited by Pycroft on
    EndersShadow Posts: 17,596
    edited January 2014
    Pycroft wrote: »
    Hi all,
    James
    Like DSkip said, it takes a Digital signal and makes it a Analog signal. Both computers and CD players can send audio out as digital. However most cd players CANNOT send SACD out over digital. They send it out over RCA.
    Depending on what integrated amp you are looking at they might not have DAC's in them. If they only have RCA inputs, then they DONT have a DAC as they only take a Analog signal not a Digital one.
    If you are looking at just CD's it might make the most sense to look at getting a nice integrated without a Dac. This allows you flexibility to change which DAC you use as technology advances, or you get the itch to try something else. This way you can upgrade your DAC w/o having to upgrade your integrated.
  • dragon1952
    dragon1952 Posts: 4,907
    edited January 2014
    Pycroft wrote: »
    Hi all,
    James
    It likely depends on the age and design of your current source. They have made continuous improvements almost on a yearly basis. Probably the main thing is how critical of a listener you are. If it's for background music it's probably not going to be as noticable. If you sit in the sweet spot and close your eyes and feel there is something lacking or something that annoys you with your current solution, you might be a better candidate. I would say most DAC's in AVR's or integrated's would probably not satisfy a real audio snob.
  • voltz
    voltz Posts: 5,384
    edited January 2014
    I have a Peachtree Decco65 and have my PC hooked up vis USB so I can play all my loss-less files through it, it takes a driver to do this and doesn't go through the Sound card. also have my cd player plug in using the optical so it uses the DAC also. My DAC in it doesnt support DSD files that you can download now.
    But I did see that Marantz has a new SACD (SA8005) that has a DAC that can so I been looking at getting one of these when they are out. (heard maybe Feb ?)
  • Indyaudio2
    Indyaudio2 Posts: 127
    edited January 2014
    If you want to dip your toe in the water, cheap, try a FIIO DO3K DAC. $27 from Parts Express. Great little unit with both digital and coax out. I have this one and am very happy with it. Have not compared side by side with my Arcam rDac.....but that was over $400.
    tonyb Posts: 33,001
    edited January 2014
    The benefit of most integrateds is the combining of the pre amp and amp stages. The dacs are for the most part an after thought in them. Separate dacs obviously would gain you more benefit but then again cost more too.
    Most higher end dedicated cdp's have some good quality dacs in them. If your using the Sony to do so, I suggest simply moving up to a better player. Just me, but I was never taken with the Sony sound in their cdp's or receivers.
  • erniejade
    erniejade Posts: 6,321
    edited January 2014
    On my Pioneer elite sc27, i used the internal dac from my old cdp, coax out to the elite, and it did make a difference on the sound of the cd's. What kind of cdp are you running?
