Carver pm60p
scottericsonon
After searching far and wide for a good power amp at the right (low) price I finally picked up a very clean Carver pm600 local yesterday off of cl...
$100 plus a tenner at rat Shack (you have questions... We have batteries) for a pair of RCA - 1/4" adapters
I deoxited the pots in it today and hooked it up to my rebuilt first Gen SDA2s
MAN!!! what a great combination! Superb tone... Deep wide sound stage... Just fantastic!
If I put my head back and close my eyes I swear I can pick out where Jerry and Bobby are standing in relation to Phil and the rest of the boys
I'm currently using my old kenwood 9g as a preamp (it has pre-outs on it) so I do believe I'm looking for a c11 and a black tuner to match or a nice black ct7
Post edited by scottericsonon on
nicely done!
some nice specs on that piece.
that Kenwood is nice, too.
post up some pics, man, so we can all enjoy!
I need to learn how to deoxit stuff. this is what you do to help with scratchy controls, right?
I disabled signatures. -
fader lube by Caig works also
Hopefully I'll do this right and you guys see a picture
Yes.... For scratchy pots my "go to" is deoxit d100 in the spray can.....
Hose the pot out inside through any opening I can find....
Work it back and forth 20 or 30 times to loosen the crud...
Another shot to "rinse"..
Let it dry for 5 or 10 minutes..
Then follow up with a couple drops of the F100L 100% fader lube and work the control a couple times to spread it out
I usually wait 5 or 10 minutes after I'm done to apply power -
cool, thanks, I'll look this up as well.fader lube by Caig works also
NICEscottericsonon wrote: »Hopefully I'll do this right and you guys see a picture
that's pretty cool that your Kenwood has preouts. I've got a neat Realistic STA-84 that belonged to my uncle. It puts out some nice sound, but no preouts so I can't see what it sounds like with some power.
thanks for the info on the cleaning. I'm gonna see if I can find some of this stuff and do a little work on the old B&K MC101 I just found. it's a little crunchy.I disabled signatures. -
Radio Shack sells little bitty cans for a truly outrageous price if you gotta have it RIGHT NOW
If not here it is on Amazon
http://www.amazon.com/DeoxIT%C2%AE-D100-Spray-NSN-6850-01-435-6478-solution/dp/B0014F110I/ref=sr_1_1?s=musical-instruments&ie=UTF8&qid=1390241678&sr=1-1&keywords=Deoxit+d100
http://www.amazon.com/DeoxIT-F100L-L25C-FaderLube-Needle-Dispenser/dp/B0018P6DPW
If you have a good guitar shop close by they may have it as well -
Nice. I wonder how a set of those in mono would run my SDA 3.1's.....HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's
