to buy or pass by
leftwinger57
leftwinger57 Posts: 2,917
edited January 2014 in Electronics
Iam looking for a very inexpensive reciever for my bedroom as the Sony STR-D-590 that I found one of the channels has gone away no matter what I do and it's a small version of a surround avr which I also have no need for but for free hell I'll try anything. I was cruising E-Bay and came across this receiver that looks ok w/ 1 glaring problem. There seems to be" special plugs to plug speakers into the amp" now the guy fully admits he just jams the wires into the unit and gets static and think it's from the way he is using the speaker ports.No sh$t, but what sort of plug was used for this and if available would something like this w/ ALL functions working make a bedroom only receiver.Even though there is a time limit and there is minor action on it I will not jump on anything that has an issue to begin with.
http://www.ebay.com/itm/Pioneer-Receiver-AM-FM-Tuner-SX-440-4-Speaker-vtg-walnut-cabinet-/141163574569?pt=Vintage_Electronics_R2&hash=item20de013529#ht_98wt_908
  • zane77
    zane77 Posts: 1,696
    edited January 2014
    I'd pass for sure, those are proprietary plugs that you will probably never find. For something cheap like this check out Goodwill or a pawnshop.
    Two Channel
  • boston1450
    boston1450 Posts: 7,758
    edited January 2014
    Pass . Look local & save shipping for a better deal if its just a bdrm set up
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • George Grand
    George Grand Posts: 12,258
    edited January 2014
    I only have about 10-15 receivers that would fit your bill.
    I also have some of those proprietary, two-blade, Pioneer speaker connectors somewhere around here.
  • leftwinger57
    edited January 2014
    Both of you are exactly right .I did a search for the plugs and are just as or even more $ than the receiver itself.Ocassional rca plugs but this w/ 2 inverted blades then screw down heads is insane.Thanks for the quick reply. Oh I went to the other GW in East Brunswick and all they have are VHS, muli dis cdp cables bowes and a bunch of schlock.To bad, I used to have great pickings between the 2 stores that are near me.The receiver barely rated at 15 watts a side for 8 ohms.Even my j2060s could use a little more.
  • boston1450
    edited January 2014
    Hit or miss at GW stores up here & prices are getting steep for banged up ready for the dumpster electronics-i go there for the albums mostly :)
    Randy-Maine
    by David WMG
  • leftwinger57
    edited January 2014
    George we should talk. I only thought you shilled LPs.When I'm ready for sure I'll p/m you and then you can mail me a list of smallish type receivers. A loty of talk about the Marantz 22xx series but they are going for mad cash w/ cabinets /w/o cabinets and led upgrades and conditions.
  • Easy Runnin
    Easy Runnin Posts: 501
    edited January 2014
    "Both of you are exactly right .I did a search for the plugs and are just as or even more $ than the receiver itself."
    Speaker pins work quite well in those receivers
    HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
    Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
    2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
    Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
    BR - Yamaha CR800/Polk monitor 5
    edited January 2014
    If I were you and I was that close to Mr. Grand, I'd take up that offer and get down there ASAP. Have you seen some of the items that George has listed on this site and their "prices"? I am 100 percent positive he HAS something you could use at a fantastic price that would also sound really really good!
    I'm hoping to get down there myself at some point because I believe he still has something I would like to bring back up here and spend some time with!
    cnh
    tonyb Posts: 33,065
    edited January 2014
    Oh hell yeah, stop by Mr. Grands....he will have stuff to make you crazy with all the vintage gear he has stacked up.
  • drselect
    drselect Posts: 664
    edited January 2014
    Definitely go see George. Wish I would have taken the chance to spend more time with him when I blew through NJ last summer.
