Time to pick your "techie" brains again.....
steveinaz
Ok, problem:
My shop is 60 feet away from my main house, and I don't have RG6 runs to it. I currently use DirecTV in the main house.
Question:
Is there some sort of device that can wirelessly transmit my DirecTV signal to the shop? I realize I could run cable, but that would involve some things that I'd rather avoid, if possible.
Question:
Post edited by steveinaz on
I saw some stuff on Amazon, http://www.amazon.com/Wireless-Video-Audio-Transmitter-Receiver/sim/B004HH5IRM/2
Questions like this are when I do a search on monoprice.com!DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
OH, caveat too: No internet out there, so streaming is out.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
http://www.amazon.com/Nyrius-NY-GS3200-Wireless-Transmitter-Receiver/dp/B008TCW2LG/ref=pd_sxp_grid_pt_1_1
http://www.amazon.com/IOGEAR-GW3DHDKIT-Wireless-Digital-Channel/dp/B00630WKGI/ref=pd_sxp_grid_pt_0_1
How bout these? they are just transmitters and receivers. -
60 feet? Common Steve, just buck up and run the RG6. In the long run, you will appreciate it. It may be some work, but it will be more reliable and probably cost you the same or less.
Bill, I think that will be my best option...I'm thinking there will be just enough room in the existing conduit.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
All these wireless senders operate at high frequencies (to increase bandwidth/amount of info transferred), meaning that any obstacle will greatly reduce the signal strength. As previously mentioned, running another RG6 run is the best solution here.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Cable companies use a direct bury RG6, why can't you ? Doesn't have to be buried deep either.HT SYSTEM-
lsi 9's -
Buy another cheap dish…ebay, etc. and install it at the shop. You can either carry your receiver from your house every time or order another receiver solely for the shop. $5/month rental fee._____________________________________________________________________________________________
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Room Treatments: GIK Acoustics -
Forgot, I have an extra older (approx. 10 years) dish at home. It has the mounting tube; don’t know if I have the mounting bracket. I’m out of the country so I won’t be able to check until this weekend. You may not receive every HD channel with it but should receive most. I’ll give to you for free if you pay the shipping. PM me if you’re interested._____________________________________________________________________________________________
DAC: Bricasti M1SE
Thorton; I apprecaite the offer, but I don't want any holes in my stucco parapet walls---it just introduces all kinds of potential problems down the road.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Buy another cheap dish ebay, etc. and install it at the shop. You can either carry your receiver from your house every time or order another receiver solely for the shop. $5/month rental fee.
Going through set up each time will be a drag. -
If you have space in and access to the conduit run, run a cable. All you need is a snake.
Mount on pole just outside the building. You will tire of watching the same channel in the shop or having someone change channel in house. Put a receiver in shed permentantly.Speakers: SDA-1C (most all the goodies)
If I "fish" the RG6 over, I'll definitely spring for a dedicated receiver. Can't do a pole type setup, HOA doesn't allow it.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
trencher rental in these parts is $80/4 hours and they provide the trailer, fyi - since i was looking it up yesterday anyway. I'm assuming trenching is not the part you're worried about though.
We're about to be building our shop and I'm running a sweeping elbow out 18" under grade and capping it off, just in case.
I had the Nyrius module; worked pretty well but it was in the same house. Not sure if you could actually change the channels when it isn't in the same house - I was able to do so with the box downstairs and the receiver upstairs.Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
In reference to those who recommended setting up a 2nd dish, have you tried to align any of these newer triple LNB dishes? They are very difficult for a DIY'er to align properly. Not like the old single LNB ones that could be aligned by hand using the signal tones from the receiver.
When I say newer, I'm talking about the ones that DirectTV switched to back around 2006. Single LNB dishes are pretty much obsolete.
Steve, I'm glad you see the light on running RG6. -
exalted512 wrote: »trencher rental in these parts is $80/4 hours and they provide the trailer, fyi - since i was looking it up yesterday anyway. I'm assuming trenching is not the part you're worried about though.
-Cody
I've got what I believe to be about 4" conduit running over from the house for all the electrical in the shop (RV 50amp ckt/lights/bunkhouse ckts/etc) to the shops own breaker box. I think I have enough room for a run of RG6, the tougher part will be getting the RG6 to my network box (from the incoming box outside of the garage) in the attached garage, as flat roofs only allow about 3ft of crawl space. My attached garage is all insulated/drywalled in. I have an access door, but there's no way to actually get up there---at least not an adult.
Cody, you'll be glad you ran that conduit.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Hire a midget!Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
I'm sure if you look at it long enough, you'll figure out a way to access it. 3ft seems like enough space to move around in. The below floor crawl space at my old house was only about 3ft tall and I did plenty of cable wiring in there.
I'll task one of my grandmonkies to climb up in there. What good are kids if they don't do chores - Norman Thayer. LOLSource: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Steve, if you have to run a cable for it, think about running a couple other cables so perhaps you can setup a small "garage" setup in there..... with say another Squeezebox or the like so you've got some of your good tunes.
Pickup a set of Monitor 7's, 10's etc."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I didn't realize that HOAs existed on ranches in Arizona...
Glad I wasnt the only one thinking that!Music is like candy, you have to get rid of the rappers to enjoy it -
EndersShadow wrote: »Steve, if you have to run a cable for it, think about running a couple other cables so perhaps you can setup a small "garage" setup in there..... with say another Squeezebox or the like so you've got some of your good tunes.
I actually have my old Pioneer SX-780, XM tuner, and Energy C-9 speaks out in the shop.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
We just happen to be the last bordering properties that got caught under "3 Canyons Ranches" HOA. Luckily our HOA is pretty mild, and they generally leave the ranch property people alone.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Thanks for making this thread which spawned the idea...haha. I'll call it Steve's pipe. Here's a picture
Good news, construction to finally FINISH my shop repairs from the 9 June storm have resumed!! They were doing some trim carpentry on the bunkhouse, replaceing the bottom 30" of the mdf skirt aroubd the bottom that got soaked/rotted/. Luckily no signs of mold on the inside wall or plate. The scaffolding was constructed to tear-out, redo the exterior stucco. They just need to do a little replacement drywall in the bunkhouse; texture and paint---and that part will be done. I was delightfully surprised to see the bunkhouse framed on 16" centers/fully insulated.
The entire South wall exterior will be ripped out and re-stucco'd due to do underlying OSB rot from leaking rain water; the remaining 3 walls will get wired/re-stucco'd on top of existing stucco. All garage doors/trim will get painted. $54k all said and done, thank God for insurance--though we'll still come out-of-pocket about $6k.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
If you use that existing conduit with that electrical package in it..make sure you use RG6 quad shield fooded cable...the extra shielding you will be thankful for...to keep out emf interference..the flooding compound will keep moisture out..just a thought...
