Question related to timber matching
jph78
jph78 Posts: 1
edited January 2014 in Speakers
Upgrading from a HTIB system and I know the center is the most important speaker so that was my first purchase. I got a CS10 a year ago and am ready to get some tower fronts now. I sampled the TSX line the other day against a RTI A7 and really liked the RTI A line better. My issue is if I got the RTI A line would the timber matching to the CS10 be that off, or would it be better to just get the TSX line to better match my center. Prefer not to switch out the center for budget reasons if I didn't have to. Some music use but mostly for home theater.
Post edited by jph78 on
  • dbKiller
    dbKiller Posts: 316
    edited January 2014
    For the most part your 3 front main speakers (center, L&R) make up the majority of your HT dialogue and if your speakers aren't timbre matched if will affect the way it sounds, especially voices. If HT is important then timbre matched components do matter.
    Home Theater: LG 60PB450; Pioneer Elite SC55; RT2000P; RT55P; CS400p; FX500; SVS PB12-Plus/2; PS3 360GB
    Office: Onkyo TX-NR616; RT2000i; RT800i; CS400i; DSW Micropro 4000; XBOX 360 250GB; LG BR370; Panasonic Plasma
    Bedroom: Sony STR-DH820; CS400p; RT55p; Sony Grand Wega 55"
    Retired: Sony STR-DN840; Yamaha HTR-6130; Sony STR-DN520; Paradigm Phantom V.3; Paradigm CS-270V.3, Cinema ADP V.3, PS1000 V.4; Polk S6; Onkyo TX-NR809; Monitor 50, CS1; FXi3; PSW350
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2014
    Try it out before you decide to change out the center channel. Only your own ears will know if not having them matched will bother you. None of my speakers match and I think it sounds just fine.
    mhardy6647 Posts: 35,232
    edited January 2014
    timber matching? hardwoods to hardwoods; firs to firs.
    Timbre matching? different story...
