Which tubes should I roll first on my integrated tube amp
dhart86
dhart86 Posts: 1,594
edited January 2014 in Electronics
I have the Yaqin MS 300 SET (integrated) Amp. The tube compliment is a pair of 300b Power tubes, a pair of 6sn7 driver tubes, a pair of 12AT7 voltage regulators and the 5u4gb rectifier tube.
My first question is, does rolling the 12at7 tubes make a major difference in the sonic presentation? In other word, would it be wise to invest in quality nos tubes? I dont know the role the voltage regulator tubes play in the presentation.
Secondly, if you were rolling tubes on this amp, what would your priority order be? and why?
Thanks for any insight you can give
Main Rig:
Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
Post edited by dhart86 on
    F1nut Posts: 51,794
    edited January 2014
    The driver and power tubes will make the biggest difference.
  • george daniel
    george daniel Posts: 12,096
    edited January 2014
    my .02-- roll the 6sn's first.
  • dhart86
    edited January 2014
    Thanks Jesse and George..........kinda what I thought but always good to get reliable confirmation.
    Main Rig:
    Second Rig:
  • zingo
    zingo Posts: 11,258
    edited January 2014
    This is what I would do also; lots of great options out there.
  • dhart86
    edited January 2014
    zingo wrote: »
    Got any suggestions Jake?
    Main Rig:
    Second Rig:
    heiney9 Posts: 25,446
    edited January 2014
    I have a killer pair of Valvo gold pins that will fit the 12at7 spot if interested. To me all the tubes make a difference.
  • dhart86
    edited January 2014
    heiney9 wrote: »
    Thanks for the offer H9............
    I think I will try to price the 6sn7 tube market first, let me get back to you on the 12at7, when I can see where I'm going
    Main Rig:
    Second Rig:
  • larry777
    larry777 Posts: 480
    edited January 2014
    Sylvania 6sn7's sound good in my Yaqin Integrated Amp...... Mid 1950's.
    Home Theatre.............
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    2 Channel.............................
    Yaqin MC-100B
    Energy RC-70 Speakers
    Arcam CD-192 Disc Player
    Van Den Hul Interconnects
    pitdogg2 Posts: 27,069
    edited January 2014
    The cold ones for sure...cause they will melt yo finga
    sorry couldn't resist
    really try this guy:http://stores.ebay.com/Perpetual-Peace?_rdc=1
    great seller I have bought some from him he will treat you with much respect and there are never any worries.
  • dhart86
    edited January 2014
    larry777 wrote: »
    Thanks for the feedback larry....how do you like your yaqin 100b? I was thinking about trying to find one if I could around $500 used
    Main Rig:
    Second Rig:
  • dhart86
    edited January 2014
    thanks pittdogg.............gotcha
    Main Rig:
    Second Rig:
  • larry777
    larry777 Posts: 480
    edited January 2014
    dhart86 wrote: »
    I really like the MC-100B. I had it a year in Nov, and just getting around to changing the KT-88 power tubes. I changed the 12AX7's first and then the 6SN7's. The amp responds well to tube changes and sounds really good. Lots of power, and you can use it as a power amp only, if you want to experiment with various Preamps. Hook up a decent source, with quality RCA's, along with a quality power cord and speaker cables and you will be more than happy with the sound. Dead quiet when you turn on the amp.
    I saw used units on Canuck Audio Mart a few times in the past but none for awhile, as they seem to go quick. All the reviews that you find on line are positive, and they mention often, how well this Amp responds to tube changes.
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    Yaqin MC-100B
  • dhart86
    edited January 2014
    larry777 wrote: »
    Just as I expected......I have the Yaqin MS 300 SET amp. Sound is outstanding, but due to the limited output (9.5 watts)
    you can only pair with high efficiency speakers. The MC 100b would allow for more speaker choices
    Main Rig:
    Second Rig:
  • larry777
    larry777 Posts: 480
    edited January 2014
    dhart86 wrote: »
    That's one of the reasons I decided to buy the MC 100B......good output power (4 ohm & 8 ohm) that will allow more speaker choice. 10 o'clock on the dial is loud, and most times I use less volume than that...in a fair sized room.
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    Yaqin MC-100B
