PSW-i225 wireless sub popping issues
tech1cw
tech1cw Posts: 4
This wireless sub works fine except for the intermittent popping sounds that occur from it. it has great sound, but I have to resort to unplugging it from the wall once it starts. I am assuming it is coming from wireless interferences from other equipment that I have or from neighbors, as I live in a small row home. I have tried switching the transmitter and the sub to all 4 other channels available, and I have tried moving the transmitter and sub to different areas, nothing helps. I am wondering if anyone else has experienced this issue and if there are any resolutions, thank you.
  • seabeerob213
    seabeerob213 Posts: 1,843
    edited January 2014
    how high do you have the volume knob on the sub turned?
  • tech1cw
    tech1cw Posts: 4
    edited January 2014
    just checked and the volume was almost all the way up. I turned it down to halfway for now. will monitor...
  • tech1cw
    tech1cw Posts: 4
    edited January 2014
    popping issue still exists with volume at halfway..
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited January 2014
    Hello,
    The best thing to do is contact Polk's CS department at: 1-800-377-7655 they can help.
    Regards, Ken
