Anyone try Nanotec cables yet?
billbillw
billbillw Posts: 7,554
edited January 2014 in 2 Channel Audio
I've been reading a lot of good stuff on Nanotec Systems cables from Japan. It seems they can be especially good for the price. I think I am going to try a set of the Golden Strada SP#79 Special/SR pair written about here:
http://www.6moons.com/audioreviews/nanotec6/1.html
Just wondering if anyone else here has tried these.
Post edited by billbillw on
  • brianle
    brianle Posts: 572
    edited January 2014
    how much for a pair of Golden Strada #79?
    edited January 2014
    Prices are listed in the 6moons review (in Yen). If you do the double run SP/SR set like the last page of the review talks about, it works out to about $20/meter for the raw cable. So that would be somewhere in the range of $120-$150 for a finished DIY set of 8 footers (unless you went with really high end terminations).
    You do have to be creative to get a set from Japan though. Most Japanese sellers won's ship to USA.
  • drumminman
    drumminman Posts: 3,396
    edited January 2014
    They do look interesting. Apparently the results were superb when using the specials for return and the SP's for signal. These guys have them in stock:
    http://store.jaguaraudiodesign.com/nanotec-systems-sr-sp-speaker-cable-kit/
    Might be a little cheaper if you can buy direct from Japan, but this is convenient.
    edited January 2014
    Not just a little cheaper, its significantly cheaper getting directly from Japan. Jaguar wants $190 for a 2.5m set of bare cable (that would be ~8ft pair). I ordered 5m of each cable from Amazon.jp for just about $100. There will be another $30-$40 added by the forwarding service, but should still be at least $50 cheaper.
  • drumminman
    edited January 2014
    billbillw wrote: »
    I cut and pasted the price into google and converted it to US dollars, but it converted into chinese yuan instead of Japanese Yen. You're right, about $40 for 5 meters.
  • B Run
    B Run Posts: 1,888
    edited January 2014
    Jaguar also sells Zu and overcharges for them, even though they're factory direct at cheaper prices.
    edited January 2014
    Nanotec? Another great use of scientific naming. From the site:
    During CES 2006 Japanese company Nanotec Systems introduced their first prototype of the Golden Strada #79 loudspeaker cable to the assembled audio world in Las Vegas. The presentation was a success to warrant full production of this cable. Nanotec’s unique use of nano-sized gold and silver particles dispersed in a colloid with natural oil is the secret to their cable quality. Coating copper wire with this colloid prevents oxidation of the copper and enhances overall electric properties.
    That sounds very interesting, but I'd feel a lot better if a couple of my Engineering friends would read this and give it a thumbs up or thumbs down. Because I am quite capable of writing in "scientese", myself. And "I" would never trust "ME"!
    That said it is possible these are great cables.
    cnh
    edited January 2014
    cnh wrote: »
    cnh
    I'm an engineer with a couple material science and metallurgy classes under my belt. From the description alone, I would say its a load of BS, but the 6moons review made me curious. There are several other positive reviews around the web as well. For the price, its seems worth a try.
    edited January 2014
    My cables are on there way from Japan. I used Amazon.jp and Tenso. Tenso's forwarding charge was less than I thought (only ~$20), so it will end up being a full $70 cheaper than an equivalent set from Jaguar Audio. Will update when I've had a chance to finish them and listen/compare with my Slates.
  • drumminman
    edited January 2014
    The reviews on 6moons have me seriously considering these. Looking forward to your impressions. What cables are you using now that they'll have to beat?
    edited January 2014
    drumminman wrote: »
    I have an old set of round Audioquest Slate Bi-wire cables. I am probably going to cut those in half and re-terminate them to get a better comparison. The Slates are about 20' long, more than double what I actually need.
  • seabeerob213
    seabeerob213 Posts: 1,843
    edited January 2014
    cnh wrote: »
    cnh
    sounds like a fancy way of saying gold and silver plated copper
  • drumminman
    edited January 2014
    billbillw wrote: »
    BB, did your cables arrive? Have you had a chance to put them in your rig?
    pitdogg2 Posts: 27,055
    edited January 2014
    billbillw wrote: »
    Bill thought about selling them?
    edited January 2014
    drumminman wrote: »
    The cables arrived, but I don't have a rig right now. Still waiting for my new integrated to arrive. Should have it this weekend though. I'm also still waiting for some new spade connectors to terminate the Nanotec.
    After I cut the Slates in half and re-terminate, I will try the shorter Slates in comparison to the Nanotec cables. After some time, will probably keep the ones I prefer most and sell the other set(s).
    edited January 2014
    well after you cut them I'm not interested. I seen 20' and just thought I'd check nothing serious just the right length so If the price was right for me. I'd be moving up from Signal Cable Ultra's. I already have some AQ interconnects so anyhoots.
    To be honest I do not believe that extra length will make a difference in theory that is...
    edited January 2014
    I think it may be that the theory says there is a difference, but in practical use, there may not be much noticeable difference. In theory double the length means double the impedance, double the inductance, and double the capacitance.
