preamp/amp question
laotzu61
laotzu61 Posts: 327
edited January 2014 in Electronics
there is a hybrid tube pre I'm interested in, a Vincent sa-31. for whatever reason, it does not have a balance control. my amp is
a parasound hca-1200, which has input level controls for each channel. it would seem the input level contols on the amp could
be used to control speaker balance. correct---or not? thanks.
"The symbol is not the reality"
Post edited by laotzu61 on
  • Phish56466
    Phish56466 Posts: 54
    edited January 2014
    Controlling the gain is more or less what the balance control is doing, if I'm not mistaken. Aren't the gains on the back though? That'd make it kind of a pain to adjust.
    Monitor 12's-RDO's and XO's done!
    Onkyo TX-SR705 AVR
    Adcom GFA-555 for power(being reborn, as I can afford it)
    Onkyo DX-C730 changer
    Onkyo CP-1057F table W/Grado cartridge
    CS300 center
    M4's for rears
    LG 47" LCD
    ROKU streaming gizmo
  • laotzu61
    laotzu61 Posts: 327
    edited January 2014
    the input level controls control the input volume for each channel. on the hca-1200, they are on the front. you normally use them in conjunction with the volume control on the preamp.
  • Phish56466
    edited January 2014
    I don't see why that wouldn't work then.
    Onkyo TX-SR705 AVR
    CS300 center
    M4's for rears
    LG 47" LCD
    F1nut Posts: 52,104
    edited January 2014
    Why do you need a balance control?
  • laotzu61
    laotzu61 Posts: 327
    edited January 2014
    I need to accent the right channel a bit due to the set-up. not the end of the world in any event; just would be nice.
