Lsi 15's - What receiver/amp
mlutanno
I am waiting on my LSi15's to come in, but I was hoping someone could help me with the receiver. From what I understand they are 4 ohm speakers, and not all receivers can handle that load. I have an older HK PA 5800 amp that I was thinking about using, but was unsure about the HK receiver to buy. I think I have narrowed it down to the AVR 230 and the AVR 430. The 230 and the 430 have the preouts to run the amp, but the 430 has more power so that I have more flexibility in setting up my system should I want to bi-amp the fronts with the PA5800. hich one of the HK's (if any) do you think would be a good choice.
PA 5800 : 85 x 5 (8ohm)
110 x 5 (4ohm)
110 x 5 (4ohm)
Left / Right : Polk RTi 70's (bi-amped)
Center : Polk Csi3
Rear surround : Polk RT55 / Polk FXi3
Sub : Under Construction
Receiver : Onkyo TX-SR605
Amp : HK PA5800
Center : Polk Csi3
Amp : HK PA5800
if you have the coin, bigger is always better, well maybe not with womenDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
