Polk RT/fx rear speakers. Which is left and which is right?
Gretsch6136
Hi all,
Do you know which speaker goes on the left and which to the right? The pair I have do not have labels. When mounted on a rear wall do the bass drivers point to the middle (facing each other) or to the sides (facing the corners of the room)?
Thanks,
Mark
Thanks,
Mark
I have mine for the sides and the drivers point forward so in the rear they would point away from each other.Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
Many thanks Zane!
