Tube Pre Amp
Toolfan66
If you were looking for a Tube Pre-Amp say in the $1500-$2000 range, what would you look at or get?
Thanks!!
Thanks!!
Post edited by Toolfan66 on
Used Joule or new/used RogueMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
BAT !!!! but I am now biased, if you can find one then for sure a Mystere pre. Mystere is high end primaluna but diff division
In addition to those, I'd also look at Melody. You could also look at Belles or a few of the items from Grant Fidelity, like the Consonance pieces.
Melody for that price cannot be done for under 3 as it retails for 5.5k but the same Mystere is almost identical in build that retails for 3k new. Both brands are high end primaluna with melody at the top of the food chain -
BAT VK5i. Can be had for around $1500-1900. U'll never look back, or need to look forward again! Just my .02"Everything I ever did in my life worthwhile I caught hell for"
Agree, every BAT I've heard is phenominal! I recommend buying one that uses 6922's and not 6H30's however as you are stuck with one choice of tube with the 6H30. That's my .02.
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
The Rogue 99 Magnum FS right in our own forum
Joule would also be my choice
Also with phonu stage for your new TT
http://www.audioasylumtrader.com/ca/listing/Preamplifier-Tube/Joule-Electra/LA-100MKIII-W-OPS-1/Line-Stage-Tube-preamp-with-outboard-all-tube-phono-stage/882992-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I'd go with the Rogue--- I like the 6sn7 sound/body.JC approves....he told me so. (F-1 nut)
Don't have one (yet...)
But this one is i your budget
Modwright SWL 9 SE
http://app.audiogon.com/listings/tube-modwright-swl-9-0-se-tube-preamp-2013-12-28-preamplifiers-11743--2 -
JoulePolitical Correctness'.........defined
President of Club Polk -
george daniel wrote: »I like the 6sn7 sound/body.
Me, too! I'm partial to the Cary SLP-98.
If you can do without XLR connections, I would put it at the top of your list! Very, very enjoyable.
Thanks again for the comp!
GAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
Thanks Guys, I don't have a lot of experience with tube pre's,
I had a belles, and was not excited about it, maybe synergy.. The Dodd ELP was nice, and the Dared SL2000 is for me just OK..
I want something that will blow me away... -
Joule, a perennial top 5 favorite.
BAT, Cary and VTL are worthy too.Political Correctness'.........defined
Tool, Joule will make you drool!Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Which Belles did you have Larry? Was it a Belles 21a pre? That's a nice pre-amp! Maybe (as you said) synergy was not in your favor though.......
Have never heard the Joule, but have heard a Cary and VTL pre and they are both good. I have owned two BAT pres and for good reason. Still recommend them (BAT), especially if you want fully balanced. If it doesn't matter if it's fully balanced, then I know Jesse's recommendation of the Joule (and brgman's) is a good one I'm sure........
Another way to go here is with a Dodd Reference. Great preamp.
http://app.audiogon.com/listings/tube-dodd-reference-preamplifier-2013-12-24-preamplifiers-78726The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Finding a Joule does not seem like it will be easy..
What are you looking to get out of a tube preamp? Bloomy, tubey midrange and more subtle highs, or tight authoritative bass with clearer more extended highs?2Ch Tube Audio Convert
I’M OFFENDED!!!! -
Also includes an outboard tube phono stage....saweeet -
yep--- that could be the last pre that one owns.JC approves....he told me so. (F-1 nut)
http://app.audiogon.com/listings/tube-joule-electra-la-150-mk2-tube-line-stage-golden-ear-winner-2014-01-01-preamplifiers-01702-framingham-ma
This could be it!!!!!Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
+1...What are you looking to get out of a tube preamp? Bloomy, tubey midrange and more subtle highs, or tight authoritative bass with clearer more extended highs?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
If your looking for a hint of warmth with solid highs without being overly bloomy, the audio research line might also be a good consideration. The sp16 has a solid phono stage and uses 12ax7. They have 2 versions with and without phono. You have a lot to choose from in your price range. Like others aksed, what kind of sound do you like?
I have to agree with everyone's suggestions here. The rest depends on your taste.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
Piece de Resistance!
http://app.audiogon.com/listings/tube-joule-electra-la-300me-preamp-2014-01-03-preamplifiers-11579Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
I have a nice dared fs in the flea market at half your budget but it sounds great if your not wanting to spend big. I can say that put together with the wyred 4 sound amp the bass is really snappy
It would be so awesome to sit in your own house in your own listening room and be able to audition say 10 different pre amps and amp combinations. Otherwise I really dont know what to tell you because I have never heard any of these. I know I really like my ConradJohnson PV2 (old technology) that I bought used for $350. I am sure these others sound good/maybe even great but how much better than what I have???
The hazards of this hobby....I got static in my head
The reflected sound of everything -
For transparency in your price range a used SAS Audiolabs 11A cant be beatRogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
.Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.
