Another bi-wire ?
voltz
voltz Posts: 5,384
I was just reading another thread about bi wiring and got confused so I started this thread (forgive me) to re-ask a question in a different way. (was not sure if I should use other thread)
If I want to add another amp to my AV receiver to power my main speakers I take it I just use a interconnect cable to hook the front right & left pre-outs to the new amp, then use new amp to drive my main speakers (Rti a7's).
Since my speakers can be Bi-Amped is it possible to have the new amp drive my lower binding posts of the RTi a7's and the main right and left speaker outs from my AV receiver to drive the higher posts? or do but sets of posts need to have separate amps to drive them?
And what about just using bi-wire cables like the AQ rocket 33's hooked to a new amp to drive the speakers? how would each compare?
Darryl
  • classic carl
    classic carl Posts: 676
    edited January 2014
    I'm not familiar with your receiver, but any that I'm aware of bypass the speaker jacks if you have connected another amp via the pre-amp outs. If you want to bi-wire, the best way is to purchase a set of bi-wire speaker cables. Bi-wiring is two sets of speaker wires to the same binding posts, or a set of bi-wire cables, which has one set of connections at the amp end and two sets of connections at the speaker end. You do not use two amps for bi-wiring. Bi-wiring and bi-amping are two distinctly different things.
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ (2x) Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2
    Teac R-919X ~ Sansui D-X111R
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Winter Residence 2.1 (laptop system):
    Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
    F1nut Posts: 52,356
    edited January 2014
    As noted by classic carl, you can't do that.
  • voltz
    voltz Posts: 5,384
    edited January 2014
    Thanks for the info :)
    I understand now how Bi-wiring & Bi-amping are 2 different things, as I have seen some Bi-wire cables like the AQ rocket 33's. curious if you think cables like these are a improvement over a (standard cable + binding post jumpers) ?
    my setup is NAD T-758 AV receiver. and I been wanting to and a amp to this to drive my main towers better, like maybe a Parasound 2250v2?
    Also since the parasound 2250 has 2 set's of speakers out (A+B) can both be used to bi-amp my towers? though my main thought right now is just to add a amp to my setup to drive them better and bi-amping is just a after though.
  • ken brydson
    ken brydson Posts: 9,096
    edited January 2014
    My opinion.. Get a set of quality wires that fit your budget, bag the bi wires, replace the cheap brass jumpers with short lengths of decent wire and call it a day...
    F1nut Posts: 52,356
    edited January 2014
    An improvement over generic zip cord? Yes. However, as Ken suggests above another choice is a single run of high quality cables along with replacement of the brass jumpers.
    That's not bi-amping.
  • voltz
    voltz Posts: 5,384
    edited January 2014
    OK Agreed :)
    I will just go with better cables and replace my brass jumpers. I did this in my other listening room with some Audio Quest type 4's from AA that came terminated with banana plugs. and they made a big difference for me when I also changed out my interconnects with some Kimber Cables and everything sort of started to burn in. Not sure what I will use for cables, but it will be something different this time.
