Amp or center?
northernwind
northernwind Posts: 57
edited December 2013 in Speakers
Hi guy's I'm currently running my lsim 703 with denon x4000.I was recently able to sell my svs 12 nsd for 500 and now am debatingwither to get a amp or center.With a center I would be going with lsim 706 but amp I would be going with a emotive xpa-2.Any opinion on this would be greatly appreciated.
Post edited by northernwind on
  • northernwind
    DSkip wrote: »
    If your main use is HT, I'd say get the center. If your main use is music, get the amp. At $500, you'd be able to get a pretty hefty and better sounding amp if you're willing to go used.
    I'm mostly for music right now.Also I'm spending around 1000 for amp but I'm also from canada which is a big problem.
  • northernwind
    thanks dskip,ill def take a look.First real amp so I'm pretty excited.I worry that the a21 only has 125watts?My lsim 703 are rated for 200 watt.
  • northernwind
    I been thinking about a preamp but my denon has multi eq xt32 which I think is absolutely necessary for my room.Any way I can incorporate the eq with the pre?
