HOw hard are the Polk Speakers to get into WRX??
3torex
Looking for the easiest Polk speakers to get into the doors of the WRX.... I know there aren't a lot of options ... i'm just not into cutting and rigging audio anymore.
Post edited by 3torex on
You get can almost anything in there
Check out this site for spacers!
http://www.iaperformance.com/catalog_subaru.asp
Mmmm... MM6 in the doors.
I drive the Silver wagon that on the Polk site, but it's changed a lot since then. I will get pictures in a few weeks once I get everything put back together.LSi 9/C/FX
Arcam AVR-200 -
Wow these are perfect!! Thanks!! Thin or Thick kit??? Or does this depend on the speaker I choose??? Any suggestions for the front and rear??? Since you already have a proven set up??? I'd like to keep with Polk but I'm open to anything.
Thin or thick depends on the speaker you are using. They have a small guide on their website.
I am using EX3 6.5" components in the front, and EX3 5.25" coaxes in the back (not installed at the moment, but will be re-installed soon). Then I have a MM124 in the back for some boom
Two Zapco AG200 amps, one driving the doors and the other driving the sub. All Symlink cable, and the source is an Empeg head unit. 50gigs of MP3s
LSi 9/C/FX
Arcam AVR-200
