Power centers
Phish56466
Phish56466 Posts: 54
edited January 2014 in DIY, Mods & Tweaks
I'm debating whether or not to build one or buy. I 'MIGHT' get what I want if I buy. I KNOW I'll get what I want if I build it. My question is this : How many of you have attempted this with acceptable results? Any verdicts?
Monitor 12's-RDO's and XO's done!
Onkyo TX-SR705 AVR
Adcom GFA-555 for power(being reborn, as I can afford it)
Onkyo DX-C730 changer
Onkyo CP-1057F table W/Grado cartridge
CS300 center
M4's for rears
LG 47" LCD
ROKU streaming gizmo
  • Speedskater
    Speedskater Posts: 495
    edited December 2013
    Does it have to be pretty?
  • Glen B
    Glen B Posts: 269
    "Power center" is a loose term that could mean many things. Exactly what features do you need ? Just a place to plug in power cords ? Something with an AC noise filter ? Fancy outlets and wiring ? Building one seems like overkill for a mid-fi system IMHO. You can find anything from a basic aluminum case power strip to rack/shelf mount power center with rear-mounted power outlets starting under $50. I use a Belkin PF-60 conditioner with my modest HT system. My primary need is that it provides a centralized location in my rack where I can plug everything into. Its AC noise filters, surge protection and triggered outlet banks I consider bonus features.
    http://www.hammondmfg.com/pb98.htm
  • Phish56466
    Pretty would be nice(to make the wife happy). I want function! THANKS for the link Glen, this is in the neighborhood of what I'm considering. STRAIGHT FORWARD! I've seen a few posts here where people had 1:1 isolation transformers and line filters installed, with decent receps and whatnot. I was wondering if more clarity could possibly be obtained by doing something this drastic?
    Onkyo TX-SR705 AVR
    CS300 center
    M4's for rears
    LG 47" LCD
  • zingo
    zingo Posts: 11,258
    I really like my TrippLite LCR2400 with voltage regulation; built solid and rated for 2400w.
  • Glen B
    Glen B Posts: 269
    edited January 2014
    Phish56466 wrote: »
    For the past 9 1/2 years I have been running my main system off such a DIY setup with balanced isolation transformers, audio grade wiring, receptacles, etc., where I can hear the improvements. As stated above, I use the Belkin PF-60 with my more modest HT system, where I feel more costly "conditioning" is unlikely to be worth the expense and effort. Belkin packs a lot into the PF-60 for the price. Each outlet bank, except for the high current amp set, is isolated by an L-C filter network of common-mode chokes (CMCs) and noise suppression caps, plus ferrite chokes.
    Belkin PF-60 inside view:
    belkin_zps16c121f8.jpg~original
    My balanced power units:
    B2_09.jpg~original
    B2_08.jpg~original
    b_09.jpg~original
    b_08.jpg~original
    b_10_zpsba509415.jpg~original
  • Phish56466
    edited January 2014
    You were the gent with the pics I saw. Thanks for the input man!
    Onkyo TX-SR705 AVR
    CS300 center
    M4's for rears
    LG 47" LCD
