Correct position for Left & Right HIGH speakers
fabianlupidi
fabianlupidi Posts: 1
I'm mounting the speakers I've bought. RTiA7, CSiA6, Fxi4 and RtiA1 for L&R high. I'll use them with an 55" TV and an 120" screen projection. I'd like to know the best position for the L&R high, as I'm NOT using Side surround, only Rear Surround (Fxi4). Thanks.
  • zane77
    zane77 Posts: 1,696
    edited December 2013
    Sorry just saw that you were referring to the high position and I haven't used that Jin my setup.
    Two Channel
  • Rocco1
    Rocco1 Posts: 190
    OP..........
    Any luck finding the answer else where yet? I am thinking of adding RTiA1s to my set up as Heights as well. Didnt know if they needed to be near the ceiling or if above the fronts was just fine.
    Man Cave: 7.1
    -PS Audio Power Plant Premier
    -PS Audio Power backup
    -Onkyo Pre/Pro> 2 Adcom555se bridged and bi-wired> RTi A9s
    > Adcom GFA 7605> CSi A6 center, RTi A3s side rears, FXi A6s rears
    >Sub = MK Audio 10'
    -PS3
    -Onkyo 5 disc cd player
    -Directv
    -Samsung 59' plasma flanked by 2 Samsung 43' plasma's
  • monepolk
    monepolk Posts: 1,154
    I remember reading that they should be above the LR speakers pointed at a 45 degree angle to your listening position. Not sure what height that turns out to be.
  • recoveryone
    recoveryone Posts: 930
    That height requirement is dependent on room size, listening position and so on. the only constant is that the height speakers should be 1-1.5 feet offset (outside of mains). The ideal is to create a more spacious front sound (depth)
  • rpf65
    rpf65 Posts: 2,127
    edited January 2014
    Ideally you want the front heights set at 45 degrees from the listening position, both horizontally and vertically. Otherwise as close to the ceiling as possible and as close to 45 degrees as possible. If your mains are at a 35 degree angle this would be about 1.5 to 2 fet outside the mains.
