Chord for cable tv?
Greenandwhite23
Alright so in my room I have cable, but not time warner with the 1000+ channels or whatever down stairs. I have a chord that connects dt/tv through the wall and that's where I get my cable tv from, so how can this be connected to my av receiver? Will I need a cable box or is there a specific cable that I can use?
thanks
thanks
Ok. Tell me if I'm reading this wrong. Are you wanting to hook your cable from the wall straight into your AVR?
I guess so, pretty much any way I can get cable without a box as I don't have one in my room. As you can probably tell im very new to this.
Np. You will have to go cable to TV and HDMI to AVR .
That's if your TV has an HDMI out.
If not and your TV has an optical out and your AVR has an optical input
If none of te above you'll need a cable box2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Looks like the tv only has hdmi ins not out.
It should have a spot for a coaxle cable TV wire. You plug it in there and a digital toslink cable from the tv to the receiver. If the tv has a digital out.HT SYSTEM-
lsi 9's -
txcoastal1 wrote: »That's if your TV has an HDMI out.
^^^ This. Most TV's do limit optical to 2ch. -
Ok here's what my tv has:
4 hdmi ports one of which I connect to the hdmi out on the receiver.
Ac in
spdif
Dtv/tv (where the cable chord connect from there to the wall)
Component ports
Rgb pc -
spdif should be digital audio output, that can go to your receiver. You will need a toslink or digital optical cable. They are very cheap on both monoprice and amazon.
This should do:
http://www.amazon.com/AmazonBasics-Digital-Optical-Audio-Toslink/dp/B001TH7GSW/ref=sr_1_1?ie=UTF8&qid=1387330977&sr=8-1&keywords=toslink+cableLiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Ok thanks. Do you think buying a cable box would just make everything easier for me though?
You can do it either way.
I prefer having all my HDMI sources i.e. PS3, Bluray player, Cable box etc going to my AVR then out to my TV. I do have friends that have there setups configured all HDMI's into TV and optical out to receiver using there TV remote to select inputs...but to each his own.
There are fee's for the cable box2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
yea the issue is 1) switching and 2) dolby digital. Are you running a surround setup? I know with my bedroom setup, even though my tv us supposed to be able to pass through DD out the digital output, I cannot for the life of me get it to work. But its not a big deal to me in there, and I use a harmony remote which does all the switching for me. All things considered it probably would be easier with the box if the cost is worth it to you.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Is your incoming cable service signal scrambled? If so, you must use a cable converter box.Greenandwhite23 wrote: »Ok thanks. Do you think buying a cable box would just make everything easier for me though?Main System: Denon DP-59L | Audio-Technica AT33EV | Marantz SA-11S2 | Classe DR-10 | Classe CA-300 | Classe RC-1 | PSB Stratus Gold i's | DIY Balanced AC Power Conditioner | Acoustic Zen and NeoTech cables | Oyaide and Furutech power connectors | Dedicated 20A isolated ground line.
Party System: Laptop #2 | Audioquest Dragonfly USB DAC | Technics SU-A6 | Acurus A-250 | Radio Shack 15-band EQ | Pioneer SR-9 reverb | Cerwin Vega DX9's | Dayton 100° x 60° horns with titanium HF/MF compression drivers. -
Yes without scrambled channels hook cable from wall to tv, then optical from tv to avr.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Some cable TV providers send the local HD channels un-scrambled. They also send low quality analog video for the more popular cable networks.
I think the best chord for cable TV is A#sus2.
C7 is no slouch, either.cristo
NAD C 545BEE cd player, Philips AF877 turntable / Shure V15V-MR with JICO SAS stylus,
Tascam 122 mkIII cassette deck, Harman Kardon 3480 receiver, Terk FM-50 antenna in the attic,
Soundcraftsmen SE550 stereo equalizer, Polk Monitor 10a speakers
(with Sonicraft/Solen/Mills crossover rebuild) -
If you have no cable box, connect the cable from the wall to the TV. Then connect the audio out from the TV to the AVR to send the audio through your speakers.Main System 2.2:
Proton AA-1150 ~ Yamaha C-4 ~ (2x) Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
(2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2
Teac R-919X ~ Sansui D-X111R
Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Winter Residence 2.1 (laptop system):
Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
