Slim(mer) Center to match M40s fronts and M30s back??
devmod
devmod Posts: 2
edited December 2013 in Speakers
Hello,
First time buyer here... So I bought the CS2 as a center without even looking at the dimensions... big mistake. ha!
My tv is wall mounted and I would like to hang the center speaker below it.
What center speaker could I use that matches my current speakers while also being as slim as possible?
Fronts M40s , Backs M30
Thanks!
Post edited by devmod on
  • drummer86
    drummer86 Posts: 441
    Might want to reconsider this as the CS1 is rear-ported. Will need some room to breathe behind it.
    Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
    Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
    HK AVR635 | Polk R30 | Sony DVD/SACD Player
  • Geoff4rfc
    Geoff4rfc Posts: 2,959
    I think you made the right "mistake".
    I had the CS2 and it's miles ahead of it's siblings in performance. I used it in a couple of different applications, shelf mounted below the TV, on a console below the TV, and, shelf mounted above a wall mounted TV.
    Very crude mount but functional (real guy stuff :mrgreen:), or should I say, Red Green stuff :)
    L brackets, wood screws, even zip ties. The speaker was black and I used an L shaped aluminum strip also painted black as front shelf support as the shelf was angled downward.
    Some bad pics;
