Can 3 channel amp be made to work with 2 channels?
GlennDog
GlennDog Posts: 3,121
edited December 2013 in 2 Channel Audio
With a spare Adcom 5503 sitting around, I was wondering if there's any way to (safely) connect this 3 channel amp and make it work in stereo . . . What say you?
As always, your insight is appreciated . . .
G
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12
Post edited by GlennDog on
  • george daniel
    george daniel Posts: 12,096
    right to right and left to left--- and you should be good to go!
  • GlennDog
    Lasareath wrote: »
    Yes, just like George said. just use two of the channels,
    You mean to just not use the 3rd channel output binding posts??
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    pitdogg2 Posts: 25,739
    yea George has confused me on that also.....My thinking was spare right to used right spare left to used left BUT to me that sounds like a recipe for letting the magic smoke out:smile:
  • ZLTFUL
    ZLTFUL Posts: 5,657
    The 5503 can be run 1, 2 or 3 channels. Just use 1 channel per speaker and you're golden.
  • boston1450
    boston1450 Posts: 7,682
    Not sure if this helps. Looks like ya just leave out your center http://www.adcom-usa.com/userguides/gfa-5503-ug.pdf
    F1nut Posts: 50,820
    I'll confuse you ****'s even more. If it's tube amp you must have a load on each output.....hehe.
  • soundfreak1
    soundfreak1 Posts: 3,414
    If its SS the amp without any load will not interfere, it will not be active.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    as 10lbs or more or less than 10 lbs..haha
