Bat vk-3
aboroth00
aboroth00 Posts: 1,106
edited December 2013 in Electronics
Thoughts on this preamp? I know it's the older version of the VK-3i but not sure why it was replaced or the differences.
2Ch Tube Audio Convert
Post edited by aboroth00 on
    F1nut Posts: 51,970
    A very nice and musical pre amp.
  • aboroth00
    How do you think it'd compare with my current Rogue 66?
    F1nut Posts: 51,970
    Sorry, I haven't heard the Rogue.
  • bobsauto49
    bobsauto49 Posts: 973
    I have the VK5i, I think it's sublime over the Jolida fusion pre I had before! I think BAT has there chit together! Period!!!!
    "Everything I ever did in my life worthwhile I caught hell for"
    heiney9 Posts: 25,496
    It's on my short list but I don't own/collect the tubes it takes except for the 6V6 and I can't start buying/collecting 6922/6DJ8 tubes when I already have several hundred pairs 12AU7, 12AT7, 12AX7 and equivalents in my stash. Hence my interest in your Rogue 66 Magnum.
  • headrott
    headrott Posts: 5,496
    I used to own the VK-3i. It is a great pre-amp! As Jesse said: musical. I sold and replaced it with a VK-31 I bought from Chris (here on the forum). The VK-31 has better transparency and detail than the VK-3i, but it's also over double the price. If you buy a VK-3(i) you will love it. You will need to start collecting 6DJ8's/6922's and 6V6's though. If you buy it, let me know I have a couple pairs of 6V6's that I can sell you to go in it. Sorry, I need my 6922's though....... I have never heard the Rogue either so I cannot comp-are, sorry. Let us know what you decide.
  • aboroth00
    headrott wrote: »
    Thanks all for the tips. I am eyeing a local VK-3 right now and am thinking about selling the Rogue and tubes. Unfortunately the Rogue is tubey and it worked great for my more analytical speakers to warm them up and reduce the sharpness in the highs. But the new speakers are totally the opposite...
    Do you know the difference between the VK-3 and the i version? I read somewhere that it is very much different on the circuit design and a total upgrade. I have already looked into new tubes and I would like to firm up the interest on my stuff before I go and spend on new gear. I will definitely consult with you if I do pick up a BAT.
  • aboroth00
    deleted
    billbillw Posts: 7,759
    THE biggest difference between the VK3 and the VK3i is the user interface, volume control, and remote capability (still an option though).
    I have attached the I-series White Paper from BAT for you to read more.
    i-white.pdf
  • headrott
    ^^^^That is my understanding as well.^^^^
  • aboroth00
    Thanks for the info. I can definitely live without a remote. One of the biggest beef with my Rogue is the motorized volume control. The potentiometer is continuous and not stepped so hitting up or down on the remote, changes the volume too much! So I got used to getting up to change the volume and just leaving it there. I was wondering if there was a sonic difference and it doesn't seem like there's much of one.
    aboroth00 wrote: »
    There is probably a slight sound difference due to using better parts, but I would guess its not significant.
